RV.Net Open Roads Forum: Tow Vehicles: Holy Horsepower, Batman
Search only in Tow Vehicles
 > Holy Horsepower, Batman
Keith99RS
Suffield, CT
Posted: 07/02/08 12:57pm Link  |  Quote  |  Print  |  Notify Moderator
Cosidering Toyota is warrantying the supercharger and such I would assume it is like the rest of their TRD items and will not void other areas. There has been a warrantied SC package by TRD for the Tacoma for years now. They just did the same for the Tundra. I don't think anyone is buying one to use it as a 1 ton hauler, but to increase performance within its limits it might be nice. As someone said mileage may not be all that bad considering the extra HP would also allow the transmission to stay in the higher gears longer. With a 6 speed already getting around 18mpg highway that would be pretty impressive as it seems that 6th gear is an economy gear.
Smoke 05 Titan SE CC 4X4
K&N panel filter
PRG 2.5" Leveling kit
Bilstein front,Icon rear shocks
Powerstop slotted rotors
18" Wrangler AT/S LT's
2009 Fleetwood Prowler 2702BS
Primus Brake Controller
Reese DC w/ 1,000lb/10,000lb WD
killerbee
PHOENIX USA, Never hot
Posted: 07/02/08 01:02pm Link  |  Quote  |  Print  |  Notify Moderator
it won't void the warranty. But the warranty has finite time frame. Assume that anything serious in cost (tranny, heads, etc) will appear 6 days after its expiration.
Its a good idea, looks tight, stealth, but you gotta pay to play. $6 g's does not cover the total cost, you should plan on that.
Having it protected under warranty is a good deal still. Or is it? of that 6 g's, you can bet a major % is warranty work.
Duramax Cooling System Evaluation
Intro to TURBODIESEL INDUCTION OVERHEATING
THERMAL FEEDBACK and INDUCTION OVERHEATING
GM Overheating
Engine Oil Cooling
FORUM for Duramax Performance
Tune Your Own GM Vehicle
pronstar
The LBC
Posted: 07/02/08 01:38pm Link  |  Quote  |  Print  |  Notify Moderator
BTW - $6K (give or take) is about the going rate for blower kits for domestic trucks. So I don't think this is out of line.
The truck should be a screamer.
But there's more to towing than sheer power alone. Otherwise we'd see Vipers and Vettes with rigs in tow...
2007 Dodge Ram 2500 CTD 4x4/QC/LB
2008 Stellar 23' Toy Hauler
8.1 Van
Millstone NJ
Posted: 07/02/08 01:49pm Link  |  Quote  |  Print  |  Notify Moderator
Since Toyota has much more cash than the big three put together it should be no big deal for them to come out with 3/4 and 1 ton versions of the Tundra pickups.
FKA PSDExcursion
2002 Chevy Express LS 3500 8.1 155" WB passenger van 3.73 posi (GT4/G80)
41 Ft 2003 Thor Citation 41-ZBSR TT w/ Hensley Arrow
BruceStarkey
Ontario, Canada
Posted: 07/02/08 05:39pm Link  |  Quote  |  Print  |  Notify Moderator
That's the ticket, build a beefier truck for the serious haulers and leave the gimmickry for the stop-light bandits.
Today is just the tomorrow you worried about yesterday!
'04' International 4400 LoPro 310Hp/950FtLbs 10Spd Harley/RV Toter
'05' Mobile Suites 38RL3
'01' Harley Ultra in the bike barn.
Jarlaxle
New England
Posted: 07/02/08 06:10pm Link  |  Quote  |  Print  |  Notify Moderator
I saw one of these on a Dynojet on the Power Tour...100% box stock except for the blower, a Dynomax cat-back exhaust, and aftermarket wheels, he put about 425HP to the rollers. Very impressive.
(Though the Chevy stepside that spun the rollers to just over 700HP was more impressive. )
John
1984 Ford B-700 school bus conversion, Thomas body
A bunch of other vehicles
3 nutty cats (Maya, Vierna, Briza)
One lazy dog (Marmaduke)
One wife (Liz)
"A wasted youth is better by far than a wise and productive old age"
-Jim Steinman
Gary C
Rose Hill, MS
Posted: 07/02/08 06:26pm Link  |  Quote  |  Print  |  Notify Moderator
The warranty is only valid if you have a dealer do the installation. If you just purchase the supercharger kit from the parts counter and have a local mechanic install it then it voids your engine warranty. Dealer installation is going to add a lot to the bill and I wouldn't want most of them tearing into my motor. A supercharger isn't going to turn a 1/2 ton into a 3/4 ton, it's just going to give you a faster 1/2 ton. I'd very seriously doubt that you could add a supercharger to the 5.7 and keep the same fuel mileage, I'd expect at least a 1-2 mpg drop in daily driving. All in all I'd say it looks like a fun toy but of no real utility to anyone using their truck as a truck.
RobertRyan
Australia
Posted: 07/02/08 06:43pm Link  |  Quote  |  Print  |  Notify Moderator
How about the weight of the vehicle? We have Utes that have turboed 6 Cylinder engines that run 410hp and 415lbs of torque at 2000rpm. They only weight 4000lb. No way are you going to tow anything more than 5000lb even with all that power and torque. What stress does towing put on the drive train and suspension?
Tim@DOA
Mooresville NC USA
Posted: 07/02/08 06:51pm Link  |  Quote  |  Print  |  Notify Moderator
killerbee wrote:
a supercharger is a parasitic accessory. How can it possibly increase mileage? Power, yes...mileage? Increasing VE is of no value if the vehicle is lean. At a 20 HP output hiway empty cruise, a supercharger is like an AC compressor you can't shut off.
Forced induction such as a SC is a parasitic loss, but it increases mileage potentially by providing more energy with less effort. Chargers take power to drive, but provide excesses of what that deficit is. VE is 100% minimum with forced induction, NA engines may be 85 - 90% at peak health. Also, forced induction does not suffer dramatically as does an NA engine at altitude. The only real drawback I can see with the Eaton charger on the 5.7 is detonation, and even though TMC warranties the engine and blower, they do not consider detonation to be an accepted fault of the package if a failure such as broken rings, ring lands, pistons, etc. were to surface.
04superduty
Michigan
Posted: 07/02/08 06:59pm Link  |  Quote  |  Print  |  Notify Moderator
fickman wrote:
I know one guy who will be exited to hear this. . . surprised we haven't already heard from him.
lol, HERE SUPERCHARED, COME ON BOY WERE TALKING ABOUT YOUR FAVORITE SUBJECT. now where is he, usually he comes running right up and adds his .002$.
04 F350 6.0PSD/TS EC SB
07 Outback Sydney edition
