RV.Net Open Roads Forum: Toy Haulers: Fuel station is popping fuses
Search only in Toy Haulers
 > Fuel station is popping fuses
dedmiston
So Cal, USA
Posted: 07/03/08 08:10am Link  |  Quote  |  Print  |  Notify Moderator
I think most of the issues with the gears happened right out of the box, not after years of use.
My pump started blowing fuses after three years of use. WW replaced the gears, but that didn't fix it. After they replaced the pump, they reminded me to shut off the pump timer after I'm done using it (instead of just letting the timer run itself down). They said that the pump is cooled by the fuel flow and that it overheats if it's turned on and not in use.
So I think I may have lead to my pump's demise.
2004.5 Dodge 2500 Diesel • 2005 Weekend Warrior FS2600
Toys:
  • 05 Yamaha WR450
  • 07 Honda CRF250X
  • 05 Honda CRF230
  • 06 Honda CRF230
  • 06 Yamaha TT-R90E
The Edmistons - Our Gallery
Never forget 9-11-01 Check out our blogs @ blog.rv.net
nwcutie
Washington State
Posted: 07/03/08 08:33am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for all of your responses! Does this sound like a gear issue?
It is a Holly fuel pump according to the sticker. I've been using it with no problems for 2.5 years, but now what happens is:
- I hit the timer switch (no problem)
- I go outside and flip the toggle for the fuel pump - that's when the fuse goes!
I'm not sure how to open it up or take it out or what exactly I'm looking for. Is there a site with diagrams and simple directions? I need pictures - what can I say.
Thanks again!
Children are unpredictable. You never know how high up the wall they're going to drive you
2006 F350 - SAWEET!
1998 Chevy 3500 Dually - old tow rig - now for sale
a really, really big 2006 Adrenaline 400DS
kids, quads, and a dog - life is great
lincster
Mesa Az
Posted: 07/03/08 09:02am Link  |  Quote  |  Print  |  Notify Moderator
Thanks again!
After 2.5 years of use, I don't think it is your gears.
I think you have a short somewhere or maybe the pump is just wore out?
If it works until gas starts flowing, you may have a fuel filter clogged and is causing the pump to work too hard.
2006 F350 PSD CC 4X4 Dually w/Tow Boss package to pull 2006 LE3905
Lincsters Truck/Trailer
Lincsters Rail
Racorman
Santa Cruz, California
Posted: 07/03/08 10:13am Link  |  Quote  |  Print  |  Notify Moderator
Where do you find your fuel pump fuse? Fortunately, I have not had to look for it...... but inquiring minds need to know
AKA..... 56Nomad
2006 Weekend Warrior (LE3305)
1999 Lance Camper (1130)
2005 King Quad 700
2008 King Quad 750
Haul all the toys with a Chevy 1 Ton Duramax/Allison 4x4 -Edge w/Juice and 4" Exhaust
nwcutie
Washington State
Posted: 07/03/08 08:04pm Link  |  Quote  |  Print  |  Notify Moderator
When you come in the door, the corner entertainment center is on your right. The fuse panel is the black door under the t.v. on the floor near the step.
Macs Dad
SoCal
Posted: 07/03/08 11:35pm Link  |  Quote  |  Print  |  Notify Moderator
Mine is at the main panel in the exterior cubby with the power cord. The fuse on mine also feeds my control panel. So when I turn on the pump, the pump would stop and my panel would go out.
07 Weekend Warrior SL2805
05 Chevy 2500 HD Crew Cab 6.0/410 Gasser
05 Honda 400 EX
07 Twister 150 GT
03 Honda CR 125
ScottE28516
Highland, Ca.
Posted: 07/04/08 11:13am Link  |  Quote  |  Print  |  Notify Moderator
jobfnl wrote:
I had the same issue last year. Problem was the gears in the pump were made slightly to big and over time they would bind up against the pump housing. Replaced gears and o-ring seal in about ten minutes, very easy and all good. This was a very common problem on a few different TH's in the past.
Jeff
Had the exact same thing happen too. Everyone I know who's had the fuse blowing issue has had the same thing.
`04 Ford F350 FX4 6.0, 5" Turbo back exhaust, DiabloSport Predator tuner, 4" susp. lift, 35" Pro Comps.
`05 Sierra Sport F37SP Toyhauler, flipped axles
`01 Volvo 660 HDT
`07 Yamaha Rhino 686
`04 Kawasaki KFX700
`04 Kawasaki KFX400
`07 Polaris 200
Racorman
Posted: 07/04/08 11:33am Link  |  Quote  |  Print  |  Notify Moderator
Thanks, that is where mine is also. I n
