jz1028
florida
I will be doing my trailer this week and that is a good question. I just assumed that you start at the ez flex at the center and work you way out to the spring ends.
What is the consensus on where to begin before I get underway and start pressing bolts out?
Thanks
Jay
Learjet
Louisiana
Good Sam RV Club
I took one side of the suspension completely apart, while the other side was still attached. Then, I worked from the spring ends to the center pivot attachment. Had no problems getting it to align.
2006 Nissan Titan CC with tow package added Timbrens
2006 KZ Frontier 2303P-F
Dual 6 volt GC batts
Equal-i-zer
Prodigy brake controller
Yamaha EF2600c Tri-Fuel Gen.
in the past...2001 Hurricane 30Q Chevy workhorse
Steveque
Central California
Good Sam RV Club
You may find the axle will move easier if you support the axle with a floor jack and then use a bottle jack under the front hanger of that spring. It does take a little coordination to lift and drop the jacks to make the spring move towards the rear.
I found that once I was close, I could just tug on the axle just a little to get the hole lined up.
Steve Quesenberry
Central California
2inAlabama
Huntsville, AL
Hi Guys,
I am trying to determine if I really need to do this mod. What is the potential damage to my TT over the next 10 years if I don't do it? I realize the combination of the Ez-Flex and the shocks would give the TT a smoother ride. My TT has an aluminum frame.
Just DH & DW
2007 Toyota Tundra Dbl Cab
2008 Sunset Creek 279RB, Prodigy Brake Control, Equalizer Hitch
TURK2500
2inAlabama wrote: snip.....What is the potential damage to my TT over the next 10 years if I don't do it?...snip
If your TT sits on a seasonal lot all summer, then nothing. But if you intend on putting some road miles on the TT over the next 10 years then IMO the EZ-Flex upgrade will greatly reduce the potential of leaf spring component breakdown during travel, and reducing the transfer of road imperfections to the TT can't hurt.
Turk2500
05 Jayco Eagle, 278FBS, UVW 7,063lbs, GVWR 9,000lbs.
Tongue Weight: Dry 913lbs/Loaded 1,200lbs.
02 Chevy, 2500HD/4x4, 6.0L/4:10, EC/LS/SB, Prodigy, GCWR 16,000lbs.
TV/TT loaded: 14,700lbs.
Putnam XDR Class V, Reese HP Dual Cam.
00 HD Road King Classic.
Learjet
Louisiana
Good Sam RV Club
TURK2500 wrote: 2inAlabama wrote: snip.....What is the potential damage to my TT over the next 10 years if I don't do it?...snip
Turk2500
Excellent point. I put 26,000 miles in 4 years, so I wanted and needed the upgrade because of failing shackles (see pics a few pages back).
LAdams
Northern Illinois
Good Sam RV Club
I agree... If your rig is sitting on a seasonal site, there will be virtually no wear to the suspension components aside from towing it to the site and back... If on the other hand your putting on miles like LearJet, then the upgrade is a very good idea...
Les
2000 Ford F-250SD, XLT, 4X4 Off Road, SuperCab
w/ 6.8L (415 C.I.) V-10/3:73LS/4R100
Banks Power Pack w/Trans Command & OttoMind
2006 Nomad 3150 Double Slide (Bunkhouse)
Hensley Arrow
Jordan Ultima 2020
HUNTER THERMOSTAT INSTALL
HOME MADE WHEEL CHOCKS
2inAlabama
Huntsville, AL
OK, I am going to do the Ez-Flex upgrade. While I am at it, I am wondering about installing the Monroe Shock kit from shockwarehouse.com ( http://www.shockwarehouse.com/site/mon_retrokit.cfm ). Has anyone here installed this shock kit? If so, what are the noticeable improvements for the TT ride and towing experience? Are there any complications with the install? Is it truly just a bolt-on process?
RCMAN46
NorthWest
2inAlabama wrote: OK, I am going to do the Ez-Flex upgrade. While I am at it, I am wondering about installing the Monroe Shock kit from shockwarehouse.com ( http://www.shockwarehouse.com/site/mon_retrokit.cfm ). Has anyone here installed this shock kit? If so, what are the noticeable improvements for the TT ride and towing experience? Are there any complications with the install? Is it truly just a bolt-on process? Bolt on Process?? Depends on your trailer and if there are any shock mounts already on the trailer. I have done the shock kit install on 4 trailers. I had to drill a hole in the trailer frame for the upper shock mount on all 4 trailers. On the two trailers that had I beam frames I used what is called a chain pocket instead of the Monroe kit. Monroe upper kit I got the pockets for $3.50 each. The pockets fit in the I beam perfect. I mounted them with 4 3/8 bolts. Then there is a 1/2 hole in the center and a 1/2 hole in the trailer frame. I also made a spacer from 1/2 inch water pipe that goes between the frame and the pocket. This allows full torque on the 1/2 inch grade 8 bolt that is the upper shock mount. The trailers handle much better. One is a small utility trailer. After going across a railroad track of rough spot the trailer would bounce around a little. Now it is stable as a rock. This is one I pull behind my 5th wheel. Very important it does not dance around. The 5th wheel behaves much better after the shocks.
2inAlabama
Huntsville, AL
No, my TT doesn't have shock mounts. That's why I was concerned about how this kit works. Thanks for the tips.
