downtheroad
Tumbling Waters, Washington
BlackSilver wrote: downtheroad wrote: "3 to 4 mpg more by adding a quart of oil to deisel"
Does that mean that I can add two quarts of oil and increase my mileage by 8 mpg?
Heck, why mess around with such a weak mixture. Fill up with SAE90 gear lube and you'll never run that tank dry!
Great idea. I tried it but I only got 5 mpff (miles per fuel filter)..
GMC Duramax/Allison (LBZ)
08 Komfort 277TS Our Rig Pic
Reese Dual Cam HP
TXiceman
(Near) Houston,TX
Tink about it..if you have a 35 gallon tank which is 140 quarts, you mix would be 1 in 140 or 0.71% by volume. Just another old urban myth.
ken
KE5DFR
Vintage 1979 Silver Streak Supreme Rocket toted by a 2002 F350, crewcab dually, 7.3L,4.10 axle,SCMT. Travel with two miniature Schnauzers and one African Gray parrot. Practicing for retirement!
ah64id
Idaho
One thing that I know a bunch of people doing is adding 2-stroke to the tank. On the 98-02 Dodges 24V's especially it adds lubrication back to the fuel, which has been showing improved mileage, quieter engines, and longer lasting pumps. Not 3-4 mpgs but .5-2ish. But the main reason is to save the injection pump.
I am not sure what other trucks this would benefit, mainly the pre 07 trucks that use fuel to lubricate the injection pump.
As far as running used motor oil I wouldn't do it. Years ago Cummins said you could run 5% WMO... today the eniges and oils are much different, and personally I wouldn't put WMO thru my truck.. think of all the******that is suspended in it. It would do a really good job of plugging your filter thou....
As far as 2 stroke the best results I have heard about are 1oz per gal.
'05 3500 4x4 SLT 5.9 QC LB SRW 6 spd, Pricol EGT and boost, 2" Level, Jacobs Exhaust Brake, Muffler Delete, Amsoil DIF, Smarty JR....
'07 Pioneer Spirit 18CK
ib516
Up here!
A guy I spoke to at the CG said he got ONE injector replaced on his 2008 Dodge 6.7L Cummins. The bill (paid for by warranty) was $2700.
Don't know if I'd be messing around doing things contrary to the manual if you want to keep the warranty in tact.
2004 Cougar 301 BHS 6580# Dry, 9000# wet, 9600# GVWR)
2007 Dodge/5.9L Cummins 3500 SRW Megacab 4x4/3.73
Hypertech Max Energy
"MEGACASPER" 10100# GVWR, 5200# FGAWR, 6200# RGAWR
PICTURES
ELIM 3000 Gen
Collision Reconstructionist
MEGACAB CLUB MEMBER #1
ah64id
Idaho
ib516 wrote: A guy I spoke to at the CG said he got ONE injector replaced on his 2008 Dodge 6.7L Cummins. The bill (paid for by warranty) was $2700.
By any means do not add oil to a newer, 2007+, engine.. they are engineered to run on ULSD and do not need any lubricity additives.
Personally I add Amsoil diesel concentrate to my truck every tank, for the lubricity as well as the acid fighting to help the soot loading and to help the oil last longer. I am not too concerned about clean injectors as I run a good fuel filter, and am about to put a 2 more filters on the truck, for a total of 3.
BlackSilver
East of Heaven, North of Hell
Todays engines are engineered (and the fuel is formulated and regulated) to provide consistent performance and long life (100,000 mile warrantees are routine stuff anymore) without adding snake oil. The primary benefit of Amsoil and similar aftermarket stuff is to provide an income for the vendor, not to increase mileage or any other benefit to the consumer (regardless of what their slick promotional literature would have you believe).
Hans, KØHB & Colleen, KØCKB
Master Chief Radioman, US Navy
'04 Prairie Schooner 34FBR Platinum XL
'08 3500HD Silverado Big Dooley LTZ Go-power by Max & Allie
My rig (Click)
Turtle n Peeps
California
In my 5.7 engine I'm running 49% used motor oil. And yes the mileage goes up. There is more BTU's in motor oil than #2. Just like there is more BTU's in #2 than #1 fuel oil.
No, one or 2 quarts won't improve your mileage that you can see.
outside the fire"
ah64id
Idaho
Turtle n Peeps wrote: In my 5.7 engine I'm running 49% used motor oil. And yes the mileage goes up. There is more BTU's in motor oil than #2. Just like there is more BTU's in #2 than #1 fuel oil.
While it may have more BTU's its flash point is more than double, so when your idling, or light cruising its not burning efficiently... so your loosing lots of power, and creating an inefficient burn that will be hard on cylinders, injectors, etc. There is a reason that the limit on burning is 5%... and thats on OLD engines with low injection pressures.
2oldman
WA
Where do these idiot ideas come from?
ah64id
Idaho
2oldman wrote: Where do these idiot ideas come from?
California....
