hootgipper
Sarasota, FL
Does one need to adjust/readjust the brake controller EACH time they connect the 5th wheel to the tow vehicle? For example if we disconnect at a park and stay a few days, do we need to adjust the controller when we hook back up to leave?
downtheroad
Puget Sound
I almost never touch our Prodigy.
GMC Duramax/Allison (LBZ)
Komfort 277TS Our Rig Pic
Reese Dual Cam HP
Bearnkat
Fort Worth, Texas
You really shouldn't have to readjust your controller unless your terrain changes and you feel a need for more braking power.
Chuck & Terry
2005 Pilgrim 281RB-S
2006 Ford F250 Lariat CC 4x2 PSD
My Lap-Band Journey!
Chuck and Terry's Pilgrim Adventures
C & T's Photos
North Texas Camping Association
Lone Star Dutch Oven Society
dennislanier
Georgia
It kind of depends on what brand of controller you have, but, theoretically, you should NOT have to adjust your controller each time you hook up. However, again depending on the quality of the controller, you may have to occasionally change the setting for gravel roads, wet roads, etc. A little experience will let you get a feel for when you need to adjust it, such as wheels locking up when applying the brakes on a gravel road, or not enought stopping power when going downhill etc. Before I went out and bought a new controller, I would drive mine out a few times to get used to how it works. If you decide to buy a new one, most people would probably recommend a Prodigy, but there are several brands that would serve you well. So, without adjusting every time you hook up, just drive the rig and see how it responds, and if necessary, make SMALL adjustments to fine tune it. Good luck.
goin2themountains
Aztec, NM
Tekonsha Voyager here, and yes, I adjust every time I hook up. Really want a P3 (sigh)
Puller: '04 HD2500 4x4 SB,EC Duramax/Allison. Airaid intake, 4in. exhaust turbo back, ORU leveler.
Pullee: '02 Keystone Cougar 276EFS Reese 16k w/ slider.
(map is for current 5er only)
kampinguru
Ontario
Tekonsha P3 here and I set it once and forget it. Took a little to get it set up correctly, but works very well with Boost 3 and about 8.7 volts.
2000 F-250 S/B 4X4
2005 Cedar Creek 30RLBS
Pullrite Superglide 16K
KSadler1
Albuquerque, NM
I have a Prodigy and just re-adjusted it on our last trip. I usually don't have to do that but it started getting a bit "grabby". The problem with adjusting your brake controller before each trip is that your trailer brakes really don't start working well until they heat up. With the Prodigy I adjust the controller dial after the brakes heat up and then use b1, b2, or b3 as needed. I never have to touch the dial setting. If you adjust your brake controller too high before your brakes heat up (which I did), your brakes will grab.....
Ken
Glen41
North Texas
It depends on if you have grandkids. Mine can adjust everything with a dial and throw every switch in 2 seconds flat. My point is always check the setpoint and boost. I hate surprises.
Fun is that stuff that happens in between mistakes.
2006 Chevy 3500 D/A DRW Prodigy, AirBags, CoPilot, EarPlugs
34 ft River Canyon with most of the pieces still attached
31REHauler
Orangevale, CA
I had to adjust my Prodigy during our recent trip to the coast, but that was because my grandson (He's 3) did a little adjusting of his own while "driving" Papa's truck. HAHAHAHA
My Mrs., 2 Yorkies & Me in our "Rollin' Hotel II"
2007 Legends 31RE3SLF-5 by Pilgrim International
2001 F350 7.3L PSD SuperDuty CrewCab Long Bed 4x4
Prodigy BC & Reese 15K 5'er Hitch
