pittsworld
Southside, AL.
I have a 2005 Springdale TT. I have cut the hot water switch off on the inside of the TT. But I am unable to cut off the toggle switch on the hot water tank. I just got back from our first camping trip. We had to dewinterize our TT before we left. I had to reinsert the drain plug on the hot water tank, because that was the way it was when we bought the TT. Is their something that I am doing wrong?
wayne_tw
South Dakota/Georgia
Not sure what your problem is.
mikehart92
Oklahoma
2005 Chevy 2500HD.............6.6 D/A, 4x4, Crew Cab
baldag
Chattanooga Tn
Look up threads on de-winterizing. Did you turn the bypass valves on the water heater to restore water flow? The switch in the trailer in most instances is for the wh to run on propane. The toggle switch at the wh is to operate it on electric. NEVER turn this switch on unless you are sure there is water in the wh.
George
"I was cut out to be rich, but I got sewed up wrong"
2006 Dodge Ram 2500 QC Laramie 4x4 SB CTD auto "Buck"
Flagstaff 26RLS
Hensley Arrow
Prodigy BC
TXiceman
(Near) Houston,TX
The problem is he is heating hot water...a hot water heater. My trailer has a water heater which makes water hot.
Ken
KE5DFR
Vintage 1979 Silver Streak Supreme Rocket toted by a 2002 F350, crewcab dually, 7.3L,4.10 axle,SCMT. Travel with two miniature Schnauzers and one African Gray parrot. Practicing for retirement!
javaseuf
Southern Cal
Not sure what you mean by "cut-off".
The outside switch is a rocker switch that you just push. There is a safety pin that goes through that switch but that keeps it from being turned to the "on" position.
We are a little confused here.
Whatever you do, DO NOT apply power to the water heater unless you are sure it is filled with water. If all that you did to de-winterize was to install the drain-plug, then most likely the by-pass valves on the back of the water heater are still in the by-pass mode and no water is entering the water heater.
Steve
2007 Springdale 291RKL
2003 F150 King Ranch
1991 Palomino Mustang PUP
Eureka Timberline Tent
Yamaha IF2400isc
Yamaha EF3000iSEBC
pittsworld
Southside, AL.
I turned the toggle switch on the water heater to ON. Now I can't turn it to OFF!
pittsworld
Southside, AL.
While I was camping I turn the switch inside and outside to ON. When we started home I turned the inside switch to OFF but could not turn the outside switch OFF
baldag
Chattanooga Tn
Then it's a bad switch...
George
ellenscub
Walton County, Georgia
TXiceman wrote: The problem is he is heating hot water...a hot water heater. My trailer has a water heater which makes water hot.
Ken
When I saw the name of the post I knew someone would come up with that remark. Give the guy a break. not everyone is as smart as you.
Pittsworld I'm not talking about you
Ellen
2007 27' Riverside by Adventure
2001 F250 7.3 DI PSD
