deandec
El Dorado Hills, CA
I have the blue 300 Psi Campbell Hausfield air hose that seems to be a 3/4" diameter and a yellow coiled 1/4" air hose.
I want to achieve the best mix of rapid inflation and maximum pressure I can coax from my 120 Psi onboard compressor. The front 22.5 tires need 110 lbs.
Which hose will better achieve results for me in your experience?
Dean
95 CC Magna Jeep GC
(Vietnam Vets may be eligible for medical care and disability compensation. Contact the VA if you have prostate cancer or type 2 diabetes.)
NORM WADDELL
PENSACOLA FL 32514
Larger diameter hose will reach
your desired pressure faster.
BOTH hoses will reach your
desired pressure. I doubt
there will be much difference
in the time to reach pressure.
L NORMAN WADDELL
30 FOOT ALLEGRO
SATURN TOAD
WIFE AND 2 DOGS SUGAR BEAR & COCO BEAR
javaseuf
Southern Cal
The size of the hose will dictate the rate of flow (CFM) but will not affect pressure.
Steve
2007 Springdale 291RKL
2003 F150 King Ranch
1991 Palomino Mustang PUP
Eureka Timberline Tent
Yamaha IF2400isc
Yamaha EF3000iSEBC
Bobbo
Memphis, TN
Once the air hose has reached pressure, which won't take long, the limiting factor will be the air flow through the valve stem. Unless you have an air hose so small that it passes less air than the valve stem, there will be no discernable difference.
Bobbo, Linda and the furry kid (German Shepherd)
'07 Winnebago Outlook 31C on a Ford E450 Super Duty Chassis
NRA Life Member
Near N35 12 17 W89 50 57
PapPappy
Wilmington, NC
The inside volume of the hose will dictate the pressure for a second or so, with the larger volume causing a decrease in pressure....but again, for only a fraction of a second, until the hose is actually filled with air, to the pressure set on the regulator. The 3/4" hose....and I doubt it's actually that large, will of course, put more air quicker, but the compressor may also have limitations as to output, and that large of a hose may not work as efficiently as you might think. A 3/8" hose is a good compromise.
Personally, I'd take along the smaller hose, since it won't make much (if any) difference when filling the tires, and it will be lighter and easier to stow away when not in use. Just be careful not to kink it....if it's the plastic hose I'm thinking of, it's easy to damage.
DH Bill / DW Claudia / DD Jenn / DS Chris
The Paps! Sophie, Abby, Brandy, Kahlie and Annie
Purchased April Fools Day, 2008
The Pets
DrMaserati
Salem, OR
The diameter of the hose has nothing to do with the amount of pressure, only the volume of air it can move at a given pressure. The ultimate deciding factor is the rate at which you can force air through the tiny valve stem on a tire. Hose size is pretty much irrelevant as long as it's more than about 3/16".
IH Truck collector
Lifelong RVer
"If you don't have time to do it right, what makes you think you have time to do it twice?"
deandec
El Dorado Hills, CA
Ok, thanks guys for the quality assist. Yep, I wanted to carry the coiled smaller hose during travel but got tangled up in the "bigger is better" syndrome.
Plus, Blue is a "trust" color and we all know that yellow means caution.............oh well. Holiday travel got canceled due to CA fire pollution up north so have too much unplanned time on my hands.
Wherever I happen to park
The larger hose will pass a greater volume of air up to the limit of what can pass the tire valve.
For a very long run you might notice a difference
