RV.Net Open Roads Forum: Tech Issues: workhorse fan clutch cross reference
 > workhorse fan clutch cross reference
azpete
paulden
Posted: 07/03/08 03:03pm Link  |  Quote  |  Print  |  Notify Moderator
does anyone have cross reference numbers to any aftermarket workhorse parts. i need a fan clutch wcc# w0000193.
any help is greatly appreciated.
Gale Hawkins
Murray, KY
Posted: 07/03/08 05:52pm Link  |  Quote  |  Print  |  Notify Moderator
Pete this is a critical part that many suggest the OEM part but there may be more high end clutches that are better as far as I know.
Vulcanmars
Naples, FL
Posted: 07/03/08 08:23pm Link  |  Quote  |  Print  |  Notify Moderator
I'm not sure if they sell retail but try these folks.
http://www.uptimeparts.com/
Mars
06 Rage'n FA3005
04 V10 F250 SDCC 4X4
Pullrite SG 16K
1st TH 02 Keystone Tailgator
itsalleasy
Posted: 07/03/08 08:39pm Link  |  Quote  |  Print  |  Notify Moderator
You would be better off asking for an 8.1 Chevy fan clutch, that is who made the engine. Workhorse won't mean anything to most parts people.
azpete
paulden
Posted: 07/03/08 09:11pm Link  |  Quote  |  Print  |  Notify Moderator
thanks for your replies. the oem part list for over $300.00. the fan clutch is not supplied by gm. i confirmed this with workhorse parts. the 8.1 fan clutch is 1.25 inchs less in diameter and the fan mounts with a 3/8 bolt instead of a 5/16. since workhorse does not make parts, it had to come from someone else. i just cant find a local parts house that can match it. thanks again
Gale Hawkins
Murray, KY
Posted: 07/03/08 09:28pm Link  |  Quote  |  Print  |  Notify Moderator
That is some pricey fan clutch. No wonder you are looking for the OEM source.
amxerhull
Lewiston, Idaho
Posted: 07/04/08 01:48pm Link  |  Quote  |  Print  |  Notify Moderator
I don't know if it is the same fan clutch, but I bought an OEM for my 1990 454 for $84.51 from
http://www.ryderfleetproducts.com/cgi-bin/ryderfp/pre-index.jsp
Works great.
John
Pusher
Albuquerque, NM
Posted: 07/04/08 03:16pm Link  |  Quote  |  Print  |  Notify Moderator
There have been many posts on this subject. try a search on fan clutch or specific the engine and fan clutch. The concenus was that after market clutches do not work. Three years ago I bought a GM clutch for my 454 for $178.00. Pricey but I had it exposed and decided it was to much trouble to pull out if the old one went bad.
Good luck
bacollins
Lawrenceburg, IN
Posted: 07/05/08 06:53am Link  |  Quote  |  Print  |  Notify Moderator
Hayden makes the fan clutch, www.haydenauto.com check the application guide. I believe that the one for your rig is the 2881, but check it out.
'92 Itasca Sunflyer P series Chevy
'99 Wrangler Toad
'99 Cherokee Toad
'00 Yamaha WR 400
'05 KTM 450 EXC
'92 Honda 750 Nighthawk
