RV.Net Open Roads Forum: Toy Haulers: Both Gas Gauges work
Search only in Toy Haulers
 > Both Gas Gauges work
arizonamoon
Chandler, AZ
Posted: 07/03/08 04:10pm Link  |  Quote  |  Print  |  Notify Moderator
when I press the rocker swith to check the gas on both tanks, the gauges do not work. They only move from E to just below by about 1/16" of an inch.
I checked all the fuses, but none of them list the gauges, plus none are blown. Any suggestions?
767CAPT
Olivenhain Colony, CA
Posted: 07/03/08 05:26pm Link  |  Quote  |  Print  |  Notify Moderator
Out of gas?
Quads are for people who can't ride two-wheelers...
KTM 200EXC
KDX220 Auto-Clutch
KDX220
KX100
CRF150
CRF150
arizonamoon
Chandler, AZ
Posted: 07/03/08 05:55pm Link  |  Quote  |  Print  |  Notify Moderator
uhhhh... NO.
Lake Laurashawn
Carlsbad CA
Posted: 07/03/08 11:13pm Link  |  Quote  |  Print  |  Notify Moderator
The gauges work on resistance so if it is moving, albeit a 1/16 of an inch, they are getting power and working.
You are either lower than you thought on gas (the gas gremlins took your gas) or the level indicator inside the tank is not getting a good reading.
2001 Chevy 2500 8.1/Allison 4:10 Crew Cab Long Bed
2004 Weekend Warrior 5'er
arizonamoon
Chandler, AZ
Posted: 07/03/08 11:38pm Link  |  Quote  |  Print  |  Notify Moderator
I pumped gas into both to see if the gauges would change. There is about $30 in the gen tank and $5 in the other tank. So....I know there is gas in them.
RustySocket
SW Washington
Posted: 07/04/08 08:10am Link  |  Quote  |  Print  |  Notify Moderator
Try filling them.
BShivers
North Texas
Posted: 07/04/08 10:11am Link  |  Quote  |  Print  |  Notify Moderator
What model and year trailer? What size fuel tanks?
$30.00 today at ~$4.00 gallon would only be 7.5 gallons. On a 40 gallon tank that is less than 1/4 tank anyway. Like others suggested, since you have already checked fuses and it did move, fill one tank up and check.
2008 WW FS3000 triple axle, 16" wheels, Aluminum siding.
2006 Ford F350 SRW CC/LB 6.0PSD/Auto 4x4 18" wheels/tires
11,500 GVWR
23,000 GCWR
2000 Jeep TJ 4.0/5-Spd 5.5" RE LA lift, 35" Tires 4,440lbs
www.lonestarjeepclub.org
arizonamoon
Chandler, AZ
Posted: 07/04/08 11:03am Link  |  Quote  |  Print  |  Notify Moderator
just to clarify. BOTH needles move NEGATTIVE from the E mark by about 1/16".
BShivers
North Texas
Posted: 07/04/08 01:05pm Link  |  Quote  |  Print  |  Notify Moderator
Oh! Well that makes me wonder if they are wired backwards. You may want to look at the wires going to the back of the gauge or to the tank sending unit (if possible). I don't know, maybe wires at the switch could be the issue too. Hopefully someone with more knowledge on them will chime in.
richheck
Modesto, CA
Posted: 07/04/08 07:00pm Link  |  Quote  |  Print  |  Notify Moderator
First question is did they work when you first purchased the unit and/or have they worked before ???
05 Ford F-350 4WD DWD 6.0PSD
05 Wanderer 365 WTB FW
08 Wave 295SLR FW
06 Raptor 700R
04 Suzuki Z-400
00 Yamaha Banshee
07 Kawasaki Mule
