RV.Net Open Roads Forum: Class A Motorhomes: Engine Problems?
 > Engine Problems?
buchrob
Stanstead QC
Posted: 07/03/08 08:59pm Link  |  Quote  |  Print  |  Notify Moderator
Bad/ or water in gas usually presents itself as missing or backfiring first, not just a dead stop.
I'm not a salesman for the outfit, but if you had a Scangauge attached you would know the problem within 2 minutes, as well as having a valuable trip computer available.
If you prefer, many engine code readers are available for about $100 or so from major auto parts retailers that will give you the same diagnostics.
Can't expect us humble folks who are directly plugged into your rig to do better than that.
Everyone else is just guessing.
'99 Glendale Royal Expedition 24' Class C
2003 Subaru WRX wagon as toad.
Fulltimers
Anywhere, USA
Posted: 07/03/08 11:12pm Link  |  Quote  |  Print  |  Notify Moderator
Also check your air intake for varmints.
Fulltimers
Fulltimers Weblog
2003 Rexhall Aerbus 3550BSL
W-22 Workhorse
2001 Saturn SC2 (Mr. Toad
Photos
Daveinet
il
Posted: 07/04/08 09:49am Link  |  Quote  |  Print  |  Notify Moderator
If you can reproduce the problem, there is probably a shrader valve somewhere on the fuel rail. If you bump the valve and you have good pressure but won't start, its not a fuel problem. Be careful where and how much fuel sprays out - we want you back to tell the end of the story.
Dave
FMCA F298817
'83 Revcon Prince 31' FWD
502 w/Thorley's & Magnaflows,
Howell/Edelbrock MPFI, Koni FSD,
Class A built for gear heads
My Revcon Website
Revconeers Forum
XP activation frustration
mhend12
Baltimore Md
Posted: 07/04/08 12:16pm Link  |  Quote  |  Print  |  Notify Moderator
Your description fits an Idle air control valve exactly. May or may not store a code and usually does not.
Mike and Alicia and Penny and Poppy the shelties
06 F350 CC Long bed 6.0
04 Laredo 29GS
Harvard
51.37N 114.42W
Posted: 07/04/08 01:21pm Link  |  Quote  |  Print  |  Notify Moderator
I second this suggestion!
Daveinet
il
Posted: 07/04/08 03:05pm Link  |  Quote  |  Print  |  Notify Moderator
Worst case scenario, wouldn't the IAC make it go into limp mode, rather than cut out completely? I realize this is Ford, but GM will not even go into limp mode with an IAC failure. IAC fails, it just won't idle, or will die when you let off the gas, because there is no ant-stall, but it will not make it cut out completely as described. If it really does cut out completely, then Ford needs to do some homework on thier FI. Yes, IAC does move around while your driving, but it should still go down the road fine without it. Just wouldn't idle.
Harvard
51.37N 114.42W
Posted: 07/04/08 04:38pm Link  |  Quote  |  Print  |  Notify Moderator
I had an IAC on a Jeep fail full closed and as soon as I let my foot off the gas she stalled and would not restart until I realized I had to keep the butterfly valve open with the gas pedal.
LVJ58
Las Vegas, Nevada
Posted: 07/04/08 06:39pm Link  |  Quote  |  Print  |  Notify Moderator
After you do all that has been recommended and you still have a problem, take it to a Ford facility and have them do a diagnostic test and perhaps that will give you a clue to what's causing your problem.
Good luck
Jim & Sherry Seward, FMCA #F342207
2000 Residency 3790 V-10 w/tags
2003 Suzuki XL/7 Towd
full-timer
Where we park it, USA
Posted: 07/04/08 06:44pm Link  |  Quote  |  Print  |  Notify Moderator
I can't help you but I had a 2000 on a ford chassis that did the same thing. I keep it for 2 years after that and never had a problem with it.
Joe
An Indian and a Gypsy
Joe and Nancy
2002 34 foot Georgetown double slide Ford V-10
towing 2004 Chevrolet Cavalier
Daveinet
il
Posted: 07/04/08 11:53pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, of course. But the OP stated that he was driving, running 1700 RPM and it just quit, so we would assume that the throttle was open when it died. Also your IAC normally is open during driving and does not home unless the vehicle is shut off. I've run data log software ever since I installed the MPFI and have been watching it like a hawk. I've never seen my IAC go to zero except under initial start up.
 > Engine Problems?
