24fb freedom
littlerock,ca
Hi to all,
I purchased a 2005 Chevy 2500hd 4x4 6.0 with the 4L80E and 4:10 gears with 44,000 miles.
I know its not going to be great on gas but great for towing. For the first few weeks it was averaging about 13mpg,which I was good with.
Then it dropped down to 9mpg OUCH!! Any suggestions what could cause this?? Any advice is welcomed.. Thanks.
old guy
Oregon (pronounced Or e gun)
build up in the throttle body or your driving habits. I pull off the intake and spray B12 carb spray into the intake. be sure the motor is not running, you are on the intake side of the air senor and you may hurt the engine some. just spray around to get the black soot off the intake then start it up (after you put every thing back together). this will help you mileage some.
mikehart92
Oklahoma
One bad tank of gas can cause all kinds of problems. Might change the fuel filter and try another tank from another store. Also, check your air filter.
Mike
2005 Chevy 2500HD.............6.6 D/A, 4x4, Crew Cab
82corvette
Southeast Nebraska
Drop in a 20 ounce bottle of Chevron Techron fuel system cleaner. Also you do not have a fuel filter outside the tank starting with the 04 model.
mikehart92
Oklahoma
82corvette wrote: Drop in a 20 ounce bottle of Chevron Techron fuel system cleaner. Also you do not have a fuel filter outside the tank starting with the 04 model.
No kidding? Some engineers need kicked in the...,well never mind.
Mike
SkiDood
Peoples Republic of Minnesota
Check your fuel pressure regulator as well.
Late model wife
2002 Daughter
2005 Daughter
2007 Ram 3500srw 5.9L Cummins Laramie. QC Short bed.
2008 Crossroads Zinger 30RB 5th wheel.
18k Reese signature series slide hitch
woodrow
Nooksack WA
Seafoam in the tank, clean the maf. get fresh fuel. check it for codes with a tech 2 at the dealer if it continues.
'07 Chevy 2500HD Classic D/Max LBZ 6Spd Ally Westin nerf's,5'' mbrp turbo back
PPE airbox mod,Hijacker 24k,uniden/maxrad,Prodigy,Magellan nav,'06 Cougar 314,265 Bfg Km's,Chrome MB 16x8's,Firestone bags,level command compressor kit
My Garage Photobucket
mikehart92
Oklahoma
woodrow wrote: Seafoam in the tank, clean the maf. get fresh fuel. check it for codes with a tech 2 at the dealer if it continues.
I would stay away from Seafoam unless you plan to install a new fuel pump soon. Dad made that mistake a few times then it dawned on him that they where going out right after a each application.
Mike
Jeepplr
Blacklick, Ohio
On the Chevy 2500HD with a 6.0 gas, speed is a mileage killer. If you go over 60MPH for any length of time the mileage drops. When I cruise over 75MPH my truck will get around 9MPG. If I can keep it at 55MPH it will get 16MPG in the rolling hills of southern Ohio with the AC on. Go slow and your mileage will come back up. At 70MPH you are cranking 2500RPM and just sucking fuel.
I have a 2002 2500HD extended cab 4X4 6.0 gas with a ProCharger Supercharger making about 450HP. I can pull a lot and go real fast but doing either costs lots of gas.
Good luck, cruise control is your friend just like slow speeds.
....I will support and defend the Constitution of the United States against all enemies, foreign or domestic...
24fb freedom
littlerock,ca
Thanks guy's for all the great advice.
Will try everything suggested!!!
