Charlie K
Arkansas
I found the truck I've been looking for except it has the 4.10 axle ratio on the rear end. It's a 2008 SB 4x4 SRW 3500 Laramie package. I will be using this truck more for driving than towing and before I purchase I want to know what the difference in mileage to expect if it would have had a 3.73 axle ratio? I know it will probably be less but don't know how much. Any suggestions from people who have them would be appreciated.
Thanks
edited 07/04/08 06:39pm by Charlie K *
crickeydog
Marietta, Ga.
I've had both and you'll appreciate the 4.10 when towing. The MPG difference to that of a 3.73 will be neglegable.
Happy camping!!! See ya'll down the road!!!
AIR FORCE RETIRED "EITHER LEAD,FOLLLOW,OR GET OUT OF MY WAY"!
2006 GMC 3500 SLT CC DRW 4X4 D/A LBZ,PREDATOR & FS2500 OIL FILTER
2004 HR PRESIDENTIAL 30 SCD 5'ER.
CHEROKEE & CHEYENNE, MINI DOXIE'S
LOADED LIKE A FREIGHT TRAIN, FLYIN LIKE A JET PLANE!!
RRyall
SW PA
These trucks have so much power that you don't need to have the 4.10. It won't hurt, and as mentioned, you won't notice any real mileage difference. The heavier the load the easier it will be with the 4.10, but again, these trucks have so much power, and right off idle, that you won't need the higher ratio IMHO.
C Schomer
Buckeye, Az.
I like my 4.10 but a lot of people don't. My worst empty mpg is 18.3 and that is all city driving and summer - AC doesn't get shut off. If the 08 is an auto you will have doudle OD and it won't be too bad on the hiway. Craig
2003 Dodge HO CTD, NV5600, 4.10. Real 1Ton - pregnant with twin spare tires, 4WD - all on the rear. Aurora 2000 turbo, Diablo Predator, 4" muffler. 98 Sunnybrook 30RLFS 5th wh. WHOEVER INVENTED WORK DIDN'T HAVE AN RV!
coolbreeze01
Redding, Ca
With the 6-speed auto, these trucks are long legged. I have the 3:73, but I think the 4:10 would be fine. Power is great, mileage is fair to poor.
2008 Dodge 3500 CTD LB SRW 4X4 6-Speed Auto
P3 Blue Ox Sway Pro
2007 Komfort 212
djgarcia95928
Chico, Ca. , USA
crickeydog wrote: I've had both and you'll appreciate the 4.10 when towing. The MPG difference to that of a 3.73 will be neglegable.
I agree! I have a 3.73 , 6spd. 04 Dodge 3500 I get 14 mpg towing a 12K 32' trailer and 19 empty.
Dick
djgarcia@earthlink.net
dfb
gardnerville
The only thing about the 4:10s is that you really don't want to drive over 65 since the revs start to get really noticed...
camping man
Central Fla.
You wouldn't need a 4.10 on that truck unless you pulling a house. My truck has 3.73s, and I still feel like I need a 7th gear on the highway, to many rpms for me, but it depends on you final trans. ratio.
05 Dodge 2500 Quadcab CTD NV5600/3.73rears
97 27ft.Sprinter 5er
Website
floridacamper
Florida/Georgia Line
If you do any hwy driving stay away from it. Poor mileage. I would look for the 3.73 with fuel prices only going up.
CLICK HERE FOR PHOTO ALBUM
SoCalDesertRider
SanDiego, CA, USA
The 4.10 will get the same mileage as the 3.73 if you drive it about 10% slower, which means slowing down to 68 mph if you normally drive 75 mph.
92F350 CrewCab 4x4 351/C6
LoadNGo service body
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
B&W TurnoverBall g-neck Curt Magnum rr DrawTite ft
HD springs Rancho9000s Bilsteins poly sway bushings
4.56's & Lock-Rite rear
