igutman1
Israel
Hello all,
I have in my rig two 6v (Trojan T105)in series, charged by a Xantrex Freedom 2500 inverter (and a solar panel of 100w).
I would like to add more batteries but there is no room for two more 6v in the battery compartment.
Will it be possible to add a 12v battery in parellel (Trojan or a another brand)?
Will this system function efficiently without one battery 'stealing' juice from the other(s)?
Will the inverter know how to deal with the different kinds/voltage ?
TIA, Isaac
Ford PSD, F350 Manual 4x4 CC SB, Firestone Ride-Rite, Rancho 9000, AIS air filter, ARE shell, Hensley hitch, Prodigy BC.
Old rig- 1999 SunnyBrook 30FK TT.
New rig- 2007 New Horizon 33f TT.
dbbls
Missouri
I wouldn't do it. I think the 12 volt would be pulling amps out of the twin 6's.
1999 F250 Superduty, V10 with Banks Power Pack
2004 Colorado 29RL 5th wheel with 3600 watt Onan
dixoncider
socal
Had a similar setup on my boat. Used a battery switch. The house batteries were the 6volts and the start and electronics batteries were 12volts. Pretty common setup on boats. You may need to also think about how it will change you charging. Here is the link to the switch. I don/t know if this place is any good but just so you know what I am talking about. For what its worth
http://www.jamestowndistributors.com/userportal/show_product.do?pid=2769&BASE
edited 07/03/08 08:16pm by dixoncider *
94 Ram 2500 Diesel
06 Ram 3500 Mega CTD Jake Brake
07 Pioneer 26BHS
Matthew_B
The boonies near Dallas, Oregon
As long as it's also a flooded deep cycle battery (not AGM or other specialty battery) you're fine.
I've had that exact setup (GR 31 deep cycle and 2 T105s) for 3 years now without trouble. Don't bother with a switch either, a switch only means that you won't use up the batteries evenly and your overall battery life will be less.
igutman1
Israel
What is the "GR 31 deep cycle" ?
Isaac
2oldman
WA
Add 12v to 2 6v
hwybnb
I have a similar configuration (factory installed) in my motorhome. The 12 v battery is the engine starting battery but is always connected in parallel with the two Trojan T-105s.
Mont G&J
Missoula, MT
Batteries connected in parallel should always be of the same type, rating, manufacture, and approximately the same age. Connecting dissimilar batteries may produce undesirable or even dangerous results. Jack
smkettner
No worries. Once connected it is just one big 12 volter.
Dixonmatco
Santa Rosa, California
Under the circumstances, I would vote for the battery switch.. Run off the pair of 6ers or the 12.. same with charging.
This is what I would use It gives you a choice of A or B or Both.
2000 Chevy Silverado 1500
2005 Komfort Trailblazer T23S
Honda EU2000I
