medic_152
Point Pleasant, WV
MY PUMA 30FQSS HAS JACKS UNDER BOTH ENDS OF IT AND EVEN WHEN THEY ARE DOWN THERE IS STILL QUITE A BIT OF PLAY IN THE MIDDLE WHEN WALKING AROUND IN THE RV. I ASKED THE DEALER ABOUT ADDING A 3RD SET IN THE MIDDLE TO TAKE UP THE SLACK BUT THEY SAID I COULDN'T DO THAT BECAUSE OF THE SLIDE AND THE FACT THAT IT MAY CAUSE IT PROBLEMS. DOES ANYONE HAVE ANY ADVICE TO HELP ALLEVIATE THE PROBLEM? (I EVEN TRIED THE OLD TRIPOD JACKS BETWEEN THE TIRES UP AGAINST THE LEAVE SPRING MOUNT BUT THAT DIDN'T SEEM TO HELP EITHER.
DYLAN(29),JENNIFER(26),KIRSTEN(4)AND COOPER (BLACK LAB1)
2006 DODGE CUMMINS 5.7L QUAD CAB 4X4 "BIG HORN" EDITION
2008 PALOMINO PUMA 30 FQSS, HOMELIGHT 5500WT (FOR BOONDOCKIN)
REESE WEIGHT DIST. AND SWAY CONTROL
"A FAMILY THAT CAMPS TOGETHER STAYS TOGETHER"
NCHornet1
Mt. Airy, NC.
The movement isn't coming from the jacks, it is coming from your tires movings. Use a good chok like the BAL choks that go between the tires. They are pricey but nothing works better. This stopped 90% of my movement. Also after you have you jacks down I raise up power jack up just a little, this seems to settle the TT on the jacks and helps with some of the movement, but the biggest factor is tire movement.
NCH
2000 Ford F350 4X4 PSD,CC, DRW
4:10's, BTM Muffler, Isspro Gauges,
Coolant Filter,CCV Mod
FTVB , Ford AIS
6.0 Cooler,SCT2 W/DP's 40 tow & 80 econo,Zoodad mod
2005 Keystone Hornet 30BHSS
Reese Dual Cam
Family of 4 saved by Grace!!!
MY TRUCK
OUR TRAILER
H & E
North Texas
I take the weight off the tires a little with a small jack between the wheels. This helps quite a bit. Also, I have started to lower the tongue jack just a little to add weight to the front stabilizers and that seems to help some. After the TT settles in the first night, I re-adjust the above. The TT still has some movement after all that but it is a lot less.
skipnchar
Topeka Kansas USA
I have a hard time imagining that using some additional support near the axles could possibly be a problem to your slide and it sounds like you are right on track about the problem. Longer trailers often have suspension bounce when stab jacks are placed at each end and this can make them uncomfortable. I can see a possible problem INSTALLING additional jacks in the center with some configurations but using screw type jack stands will accomplish the same thing. You can at LEAST test the solution by using them and their cost is next to nothing at Walmart or other sources. I use a pair under my trailer whenever I'm staying more than a single night and they work just fine. Good luck / Skip
The_Painting_Teacher
Cape Cod, MA/St. Augustine, FL
I gave up trying to get my scissor stabilizers to work. I went to Wal-Mart and bought some old-fashioned screw-up jacks for about $30, and they work like a charm. Camp on!
Dick_B
Palos Heights, IL USA
IMHO no matter what you do there will still be movement in the RV. It rests on springs so anything you do to the tires will help but not eliminate the movement.
We tried Wayne's Stabilizer which helps also PROVIDED it rests on a concrete pad. If not, the gravel/dirt moves with the RV.
If you have kids moving around there is no hope! Grownups can move more slowly.
Dick_B
2003 SunnyBrook 27FKS
2003 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
tvman44
Southwest Louisiana
Good wheel chocks and JT Strongarm Stabilizers.
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
everymilesamemory
Everywhere Around the United States
We used the BAL type wheel chocks and still had quite a bit of movement and we dont have any slides and only a 25' camper.
We added a set of stabilizers in front of the wheels and WOW what a differance. I had a god firend do the same with his 30' TT that has a slide and he said the same thing. WHAT A DIFFERANCE!
Add the extra set in front of the axles and you wont be dissapointed
Pat Bonish
Every Miles A Memory
Photo's of our Travels
When we realize our insignificance in this world,
it some how relieves the pressures from society to succeed
- Cindy Bonish
Bucky Badger
Madison, WI
everymilesamemory wrote: We used the BAL type wheel chocks and still had quite a bit of movement and we dont have any slides and only a 25' camper.
Pat Bonish
I have also did this. I must say it helped A LOT. I also have the BAL wheel chocks.
2007 Nissan Titan, 5.6L Big tow, Equli-z-er Hitch
2007 Forest River Salem 27RB LE
Member Titantalk.com
Nights camping 08 (35)
Rallies/Gatherings
IL
WI
