RV.Net Open Roads Forum: Technology Corner: Problem getting HD/DTV
 > Problem getting HD/DTV
admiral0647
Illinois
Posted: 07/04/08 12:12pm Link  |  Quote  |  Print  |  Notify Moderator
I cannot get on-air HDTV. I have a 2007 Challenger 377. My main TV is a ViewSonic HDTV. This works well on broadcast with the installed Winegard batwing on the roof.
I am camping north of Columbus OH at Cross Creek. Using the remote while on the antenna, I switch to DTV. The TV prompts to scan channels, which I do through the DTV menu option, but none are found.
Given my location, I would expect to find some. Am I doing something wrong?
Thanks,
2007 Damon Challanger 377c
2007 Toyota Yaris Dingy
2 Scotties
Jim's home page
sch911
Rochester Hills, MI
Posted: 07/04/08 12:30pm Link  |  Quote  |  Print  |  Notify Moderator
Two things come to mind to try. Make sure the input selector switch is set for Antenna for that TV, and make sure the antenna booster switch is on.
2003 Damon Challenger 348 Class A - Triton V10
Posted by Macintosh
jorbill2or
Oregon
Posted: 07/04/08 01:30pm Link  |  Quote  |  Print  |  Notify Moderator
Also all HDTV is digital and digital is in the UHF band (mostly) and is highly directional and goes less distance than the older VHF stations ( 2-13). ... the winegard antenna is directional and powered with added distance capability BUT MUST be pointed at the station antenna. where analog will come in fuzzy and you can fine tune the antenna direction .. if digital gets too weak a signal it wont tune or "see" anything . go to antennaweb.org
enter your location and it will tell you what you can and cant recieve
Bill
2000 Ford f250 7.3L 6sp man 3.73
ride rite airbags
2004 everest 343L
admiral0647
Illinois
Posted: 07/04/08 02:21pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the link..I'll try that.
admiral0647
Illinois
Posted: 07/04/08 02:22pm Link  |  Quote  |  Print  |  Notify Moderator
Both were set, so I'll try Antenna Web link.
admiral0647
Illinois
Posted: 07/04/08 03:14pm Link  |  Quote  |  Print  |  Notify Moderator
I did the search on Antenna Web and got the settings. No improvement. I scanned at each of every 10 degrees of antenna position, no signals found. I tried with and without booster turned on.
Has anyone been successful gettign DTV in their RV?
What will we do in Feb 2009? Is UHF hard to get?
John&Cathy
Climax, NY
Posted: 07/04/08 05:38pm Link  |  Quote  |  Print  |  Notify Moderator
Many of the Digital TV's have two antenna connectors. One will be labeled TV and the other DTV or something like that. If you have just one cable and it goes to the TV connector, just move it to the DTV connector and you will be all set for now. What you have to do at some time is just get a 2-Way splitter and two short cables. Just put the antenna cable into the splitter and hook up the two outputs to the two antenna connectors on your TV.
These connectors are one the back or side of the TV.
Good Luck
John - KC2RXS
badger47
Jonesboro, GA
Posted: 07/04/08 05:43pm Link  |  Quote  |  Print  |  Notify Moderator
UHF is not hard to get. Not sure what "works well on broadcast" means. Do you mean Analog? DTV is also "broadcast" as well as HD. Your solution is to trade in the Damon for a Winnie; the TV in my rig works just fine. Your internal signal distro box may be set to antenna - how about the internal switch/setting of the TV (normally found via setup menu)?
Winnebago 32G
PortaBote
Honda CRV TOAD
admiral0647
Illinois
Posted: 07/04/08 05:44pm Link  |  Quote  |  Print  |  Notify Moderator
Good Luck
John - KC2RXS
Thanks, I'll need to get behind the TV, but i'll check that out.
fpresto
Maryland
Posted: 07/04/08 07:02pm Link  |  Quote  |  Print  |  Notify Moderator
Most Viewsonics that I am familiar with only have one antenna input which then internally splits between the NTSC abd ATSC tuners. You didn't post your model number so it is hard to give a definite answer. You can go to Viewsonic Support and read the user manual for your model. Reading a manual at random the DTV button on the remote is just used to manually enter a digital sub-channel such as 70-1. For example to tune to that channel manually you would push dtv, 7,0,-1.
USN Retired
2007 Cedar Creek 30 RLSTS
2008 F350, DRW, V-10, B&W hitch,
Pressure Pro, JT Strongarms
