RV.Net Open Roads Forum: Tech Issues: Water heater
 > Water heater
francine_gary
Ottawa, Ontario
Posted: 07/04/08 06:45pm Link  |  Quote  |  Print  |  Notify Moderator
On our Coachmen Freelander, our water heater comes on for 8 minutes and then shuts off. We get approximately 2 cups of warm water. We tried turning on the water heater a couple times with the same results. Does anyone out there have suggestions for us to try?
pulsar
Lewisville, NC
Posted: 07/04/08 07:35pm Link  |  Quote  |  Print  |  Notify Moderator
Moved from Forum Technical Support to Tech Issues.
2002 Adventurer 32V - Workhorse chassis
1998 CRV toad - manual transmission
Have you seen the RV.Net Blogs? You can subscribe at Blog.RV.Net
robatthelake
Vancouver Island
Posted: 07/04/08 08:11pm Link  |  Quote  |  Print  |  Notify Moderator
Check Your By Pass Valve!
Rob & Jean 90 Southwind John Deere/Oshkosh/Freightliner Class A Ford 460/ Toad 92 Tracker 2 wd 5sp Convert Still running Great!
" Everything in it"Still" Works"
Bobbo
Memphis, TN
Posted: 07/04/08 08:54pm Link  |  Quote  |  Print  |  Notify Moderator
Welcome Francine_Gary. I am your next door neighbor. Glad you found the site.
Bobbo, Linda and the furry kid (German Shepherd)
'07 Winnebago Outlook 31C on a Ford E450 Super Duty Chassis
NRA Life Member
Near N35 12 17 W89 50 57
Bobbo
Memphis, TN
Posted: 07/05/08 09:28pm Link  |  Quote  |  Print  |  Notify Moderator
I'm at the campground next to francine_gary. In talking to him, the suggestion to check the bypass valve solved the problem.
 > Water heater
