RV.Net Open Roads Forum: Truck Campers: Atwood Camper Jack Problem
 > Atwood Camper Jack Problem
Utundra
Utah
Posted: 07/04/08 07:09pm Link  |  Quote  |  Print  |  Notify Moderator
On my 2005 Lance camper I have Atwood Ball-Screw Camper jacks with a remote control. Today while trying to take the camper off the two rear jacks would not extend but they would retract. The front jacks work fine.
When I test the power outlet at the relay panel for the rear jacks, I get nothing when extending and 12v when retracting. Front jacks work fine.
Any ideas? Is it the remote or is it the relay panel?
(I did reverse the wires in the jacks themselves to fool the jacks to get it off the truck, but don't want to have to do that all the time...)
Edit...New battery in the remote. Camper batteries are fully charged. My hearing sucks so I am not hearing anything, either extend or retract.
THANKS!
* This post was edited 07/04/08 08:55pm by Utundra *
'07 Dodge Quad Cab Dually, Cummins and 6-Speed Manual. Lance 1130.
rickjo
SW New Mexico
Posted: 07/04/08 07:18pm Link  |  Quote  |  Print  |  Notify Moderator
You can help two of us at once. I have one rear Atwood jack that just did the same thing. I can hear the relay clicking inside the electronics compartment so I suspect that and not the remote. However, I haven't put a new battery in the remote since I got it 19 months ago and think I will go do that now. Nevertheless, the extend all function works 3 jacks so ??? Maybe the extend all function sends 4 separate signals to the receiver.
On edit: It's not the remote battery. New battery, still won't extend the one jack. The clicking of the relay in the receiver is very distinct but it could be the remote.
Rick
* This post was last edited 07/06/08 07:58pm by rickjo *   View edit history
2004 F-350 4WD Crew Cab Dually w/ Airlift air bags, Luverne brush guard, side steps and splash guards.
2007 LanceMax 1181 loaded, wider aftermarket custom mattress (driver's side locker omitted).
"Leave the trail a little better than you found it."
Butch50
Roseburg (not for much longer), OR
Posted: 07/04/08 08:39pm Link  |  Quote  |  Print  |  Notify Moderator
I don't know about the Atwoods but I had a problem with my Happyjacs once. One would not work so I opened up the control box and I had a 20A fuse that was blown. Replaced it and everything was working again. Probably not your situation as you can raise the jack just not go down with them. Just a suggestion you might want to look at.
Butch
2006 F550 CC 4X4 Lariat PSD/Torqshift Dark Shadow Grey Metalic w/Manning F350 bed
2009 Excel Limited 30TKE (Now have it)
2006 Dodge 3500 Laramie 4X4 QC SB SRW/Cummins 6 speed Jake exhaust brake
Gary3
Windsor, ON
Posted: 07/05/08 05:40am Link  |  Quote  |  Print  |  Notify Moderator
When I had problems with my happijacs I called the company and someone always helped right, away does Attwood not have a helpline?
Gary  Lance  1181 solar Gen.
rickjo
SW New Mexico
Posted: 07/05/08 07:42am Link  |  Quote  |  Print  |  Notify Moderator
It's a holiday weekend here. Sounds like a Monday morning task but until then, since the topic was posted...
Rick
Whiteline
San Diego CA
Posted: 07/05/08 08:39am Link  |  Quote  |  Print  |  Notify Moderator
Try Atwoods number off their Products manual.
815-877-5700 or atwoodmobile.com
I have not had that problem yet but would be interested in hearing their reply. Good Luck
Lance 2005 Model 1025 Stock w/Gen on GMC 2500HD w/8.1 Gaser @ 12 mpg
Flyfisher86
Boiceville NY
Posted: 07/05/08 10:50am Link  |  Quote  |  Print  |  Notify Moderator
I had same problem with my 05 Lance turned out to be bad remote. Was replaced under warranty by dealer. I believe this is a common problem with their remotes. The only difference with mine it was the fronts that didn't retract.
2004 Dodge 3500 SRW CTD 6SPD
2005 Lance 920
Utundra
Utah
Posted: 07/05/08 03:23pm Link  |  Quote  |  Print  |  Notify Moderator
I'll give Atwood a call. I hope they will offer some goodwill since they are out of warranty. Saw a price for the remote of about $250, OUCH!
Utundra
Utah
Posted: 07/12/08 01:35pm Link  |  Quote  |  Print  |  Notify Moderator
I emailed Atwood last week but have yet to receive a reply. Maybe I fat fingered my email address in their web form. For now I will give them the benefit of the doubt and try the email again.
Gary3
Windsor, ON
Posted: 07/12/08 03:19pm Link  |  Quote  |  Print  |  Notify Moderator
If you ever want something to happen quick use the phone and don,t leave a message keep calling back till you get a human voice.
