RV.Net Open Roads Forum: Dinghy Towing: Cool Tech question
Search only in Dinghy Towing
 > Cool Tech question
Pigkisser
West Texas
Posted: 07/04/08 07:21pm Link  |  Quote  |  Print  |  Notify Moderator
I just installed a Cool Tech wiring harness on my 2008 Jeep Wrangler toad. Since I am using a Ready Brake which activates the vehicle brakes via the brake pedal, do I need to pull the M-1 brake light fuse? Or, does the Cool Tech harness have diodes or other devices that eliminate the need to pull the Jeep's brake light fuse?
2007 Jayco Seneca 33SS
2008 Jeep Wrangler 4 door 4X4 toad
Ready Brute/Ready Brake tow bar/brake combination
Igloo Ice Chest
offthewall
New Jersey
Posted: 07/07/08 04:15pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, you will need to either pull the M1 fuse or otherwise defeat the Jeep's brake light switch (RoadMaster Brake-Lite relay or toggle switch).
2008 Gulfstream B Touring Cruiser
Pigkisser
West Texas
Posted: 07/09/08 07:00pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the help!
Bumbie
El Cajon, CA
Posted: 07/12/08 07:10pm Link  |  Quote  |  Print  |  Notify Moderator
Pull the M1 fuse as well as the IOD fuse and you'll be set to go. We just finished a 5100 mile trip pulling our '08 Wrangler without a problem. I also have the Cool Tech harness.
'05 Safari Simba 33' and loving every minute!!!!
jeep2relax
Lakeside, CA
Posted: 07/12/08 11:07pm Link  |  Quote  |  Print  |  Notify Moderator
same issue with my Grand Cherokee, I pull the Brake Light fuse.
A small zip tie on the fuse makes it easy to pull.
