RV.Net Open Roads Forum: Fifth-Wheels: dual pane windows
 > dual pane windows
puzzie63
Chamberlain, SD 57325
Posted: 07/04/08 09:00pm Link  |  Quote  |  Print  |  Notify Moderator
Anybody know where a good dealer is and is the dual pany windows worth the money. I have a 5th wheel with 14 windows.
Rolling Condo
South Carolina
Posted: 07/04/08 09:10pm Link  |  Quote  |  Print  |  Notify Moderator
Check out All-Rite. They do custom dual pane windows.
'90 GMC R2500 7.4L
'90 Avion 34V
Reese Dual Cam HP
Prodigy
rhillx4
Huntington Beach ,CA
Posted: 07/04/08 09:28pm Link  |  Quote  |  Print  |  Notify Moderator
WOW those are quite costly.
2002 Dodge Ram 1500 Quad-Cab
2008 Jayco JayFlight 26BH
Charlie D.
Gonzales, La.
Posted: 07/04/08 09:29pm Link  |  Quote  |  Print  |  Notify Moderator
There was a post on here a few weeks ago. You might do a search and find the OP. He may have some answers on what he found.
You will need deep pockets for a retrofit. I tinted all of mine and it has reduced inside temps. by 10 degrees.
Enjoying Your Freedom?
Thank A Veteran
2007 Holiday Rambler 32SKT
2006 Chev LT D/A CC
Fulltimer50
Zephyrhills , FL
Posted: 07/05/08 05:25am Link  |  Quote  |  Print  |  Notify Moderator
Storm windows are a much cheaper retrofit.
George
99F250XLT/SC/LB/4x2/3.73LS/gauges/JNB BypassReg/Ford AISw/ Airlifts/Rancho 9000s/DS Predator Tuner/203*TS/Coolant filter/OptimaRedTops/Jimmyjammers/Oilguard/MBRP 4"turbo back/Suncoast Extreme tranny/BD EBrake.
06 Newmar Cypress 29KSRE 5th wheel
Bumpyroad
Virginia
Posted: 07/05/08 06:05am Link  |  Quote  |  Print  |  Notify Moderator
yep, and RV dual panes aren't as good as the household variety. expensive to replace when they go bad, and they will go bad. get storms and heavy drapes instead.
I had them on a previous MH and didn't bother ordering them on my current one. JMHO
folks here that have them seem to promote them, but I would be willing to bet that those who do haven't had to replace a bunch of them YET.
bumpy
tom_kat
way upstate new york/lake george area
Posted: 07/05/08 07:04am Link  |  Quote  |  Print  |  Notify Moderator
i made storms from plexiglass and they work good,they do make a differance in the heat and cold.tinting windows helps some also.
1985 Class A Holiday Rambler Imperial 33 +1979 Class C Holiday Rambler Statesman 1000 = 24 ft
NC Hauler
Asheville NC
Posted: 07/05/08 07:16am Link  |  Quote  |  Print  |  Notify Moderator
I'd highly recommend them/with tint. This is my 3rd. 5er with dual pane windows and I've yet to have a problem with any of them. In fact the 02 Coachmen Somerset that had them was bought by a friend of mine,
I see the unit quite often, at 6+ years, there are no problems with his dual pane windows at all, no fogging up, no leaks, I got to admit,
even I've been impressed. I'd say it's far cheaper to buy a unit that already has them, then to retro-fit them. I'd also say that you can't judge ALL dualpane window "situations" by one experience,(early poster
had a bad one), or by me,(obvious good experience). It is what it is.
Even home installed storm windows have their problems and can be costly to repair
Jim & Kathy
2007.5 Chevrolet K3500DRW/CC/LB/LMM/D/A LTZ, Prodigy,Reese 20K hitch.
2006 HR Presidential Suite 37RLQ (4 slides).
2007 Mitsubishi Outlander XLS 4X4
Boxers: Sheba, 13...Buddy..1 yr.
USAF 71-75 Nam Vet
houtrz
Lake Jackson Texas
Posted: 07/05/08 07:46am Link  |  Quote  |  Print  |  Notify Moderator
I talked to a lady that repaired my home glass last month and although I don't have dual pane windows at home, I asked about them and she said they loose their gas fill in five to eight years and have to be serviced which is expensive. Are the dual pane windows in an RV gas filled like those on a site built home or are they just two panes of glass sandwiched together with a dead air space in the middle?
Kountryguy
Emery,SD
Posted: 07/05/08 07:49am Link  |  Quote  |  Print  |  Notify Moderator
Just one more vote in favor of dual panes. I have a 99 Kountry Star, no problems, knock on wood! They make the trailer much more comfortable.
 > dual pane windows
