RV.Net Open Roads Forum: Travel Trailers: Rattling Vent Cover
 > Rattling Vent Cover
alltenofus
Early, Tx
Posted: 07/04/08 10:29pm Link  |  Quote  |  Print  |  Notify Moderator
The standard 14" vent covers on my TT rattle when the wind blows due to slop in the slot and raising arm. Very irritating when I would like the trailer quiet for reading, naps, etc. Will MaxAir covers fix this? Or is there a brand of vent cover that is quiet? I have to replace the existing covers due to deterioration of the cover material- developing holes on the edges.
4perks
Harvard ILL
Posted: 07/05/08 12:24am Link  |  Quote  |  Print  |  Notify Moderator
MaxAir covers are the to keep the rain out, so you can have your vent open. It may help, it will reduce the amount of air that will be blowing against it.I just put one on my 2008 and it makes all the difference. Now when it is raining I can leave the vent open. If it rattles that bad I would replace it and put the maxair cover on it too. Good luck.
NCHornet1
Mt. Airy, NC.
Posted: 07/05/08 06:12am Link  |  Quote  |  Print  |  Notify Moderator
Yes they will help, also some wd/40 or the like on the hinges and other moving parts will help quite it down.
NCH
2000 Ford F350 4X4 PSD,CC, DRW
4:10's, BTM Muffler, Isspro Gauges,
Coolant Filter,CCV Mod
FTVB , Ford AIS
6.0 Cooler,SCT2 W/DP's 40 tow & 80 econo,Zoodad mod
2005 Keystone Hornet 30BHSS
Reese Dual Cam
Family of 4 saved by Grace!!!
MY TRUCK
OUR TRAILER
tonyandkaren
pennsylvania
Posted: 07/05/08 12:19pm Link  |  Quote  |  Print  |  Notify Moderator
Replacing the vent covers will solve the problem for awhile but everything will get sloppy again with use and the rattles will be back. We found an easy fix if you don't want to go to the expense of installing MaxAir covers. Buy some of the littlest bungy cords that you can find. Hook one end to the cross bar on the frame and the other end to the cross bar on the vent cover. Adjust until there's a little tension when the vent is opened. Almost total silence , even on windy days. You may have to drill a few small holes in the cross members.
