salem
Central Valley, Ca
We have a very tight driveway. In order to back 5er in, I have to back up over the curb. I'm looking for suggestions, websites, etc. or photos of home made ramps. Thanks in advance.
mister_d
Livonia, MI - hardly qualified to be a
I have no idea if it'd work, but the first thing that came to mind was to flip a cpl of those triangular wheel chocks over. Another thing I thought of was the number of different sized/shaped curbs out there. The ones in front of my house are a bit rounded which would backing over much easier than others.
2007 Rockwood Roo 23ss
Derek '77
Tina '78
Brianna '04
Dominick '07
Maximus (slobbering camping buddy)
J-mans Dad
SF Bay Area
Depends on how deep your curbs are, and if they are square or round shouldered.
When I put my 5er away, I have to back over a 6" square shoulder curb.
I end up with 2 2x6 as a base then single 2x6 then a single 2x4 to ramp up to the sidewalk height.
like this:
|2x4|
| 2x6 |
| 2x6 || 2x6 |
I reuse the 2x6's as leveling boards as I have double axels and sometimes the lynx blocks aren't enough.
All of the 2x6's came from leftover projects, but even if I had to go buy a few, they're still inexpensive compared to buying ramps or justifying a curb cut with the city plus you can make the ramps as wide as you need.
NanciL
Bakersville, NC, USA
Do it the same way the construction people do it.
Use as many pieces of 2 x stuff as necessary on each side of the curb to make a smooth transition over it.
Jack L
Jack & Nanci
Wherever I happen to park
I would go with a 2x4 bevel one edge to 45 degrees. if that's not enough put a 2x6 under it also bevel the "Street" edge and bolt them together, if that is not enough put a 2x8 under it (the same bolts,
And so on
donee
Simi Valley, Ca. 93063
Our MH has about a six foot overhang from the rear end to the axle.
I got a pair of plastic curb ramps and they work great.
Painted the curb in a couple of places so I can hit the same spot when backing in.
05 Monaco Esquire 29PBD
05 Silver Dodge Cummins w/3.73 gears 4 spd auto.
HUTCH45
NORCAL
You might get some ideas here...index on the left side of page.
'Homemade' ramps are pretty easy though as others have mentioned.
www.discountramps.com/atv-carriers.htm?gclid=COOk_dHntY0CFQoBYAodbT-GFQ
"HUTCH"
'07 SILVERADO 3500HD 'CLASSIC' DRW - CC - 4 X 4
'07 NEW HORIZONS 35' 5th.Wheel 'MotoMover'
'06 HONDA 106hp.VTX1800 w/'HANNIGAN' Sidecar
"PRIMO" The Boxer
2007dura
Hendersonville, NC
You could use the lego style leveling blocks to form an incline, or here is a curb ramp.
2007 Classic 3500HD DRW/LT3 Duramax/Allison
2008 Jayco Designer 35RLTS
salem
Central Valley, Ca
Thanks 2007 dura, that "curb ramp" looks interesting. Think I'll give them a call and check it out. Thanks to all who replied. I don't actually have enough old 2x4's to cut up and make my own. If I had to go buy them, it'd be about as cheap to look in that "curb ramp."
donee
The ramp that 2007 posted is the same one Im using and it works very nicely.
