RV.Net Open Roads Forum: General RVing Issues: Backing over curbs
 > Backing over curbs
salem
Central Valley, Ca
Posted: 07/04/08 11:49pm Link  |  Quote  |  Print  |  Notify Moderator
We have a very tight driveway. In order to back 5er in, I have to back up over the curb. I'm looking for suggestions, websites, etc. or photos of home made ramps. Thanks in advance.
mister_d
Livonia, MI - hardly qualified to be a
Posted: 07/05/08 12:02am Link  |  Quote  |  Print  |  Notify Moderator
I have no idea if it'd work, but the first thing that came to mind was to flip a cpl of those triangular wheel chocks over. Another thing I thought of was the number of different sized/shaped curbs out there. The ones in front of my house are a bit rounded which would backing over much easier than others.
2007 Rockwood Roo 23ss
Derek '77
Tina '78
Brianna '04
Dominick '07
Maximus (slobbering camping buddy)
J-mans Dad
SF Bay Area
Posted: 07/05/08 12:53am Link  |  Quote  |  Print  |  Notify Moderator
Depends on how deep your curbs are, and if they are square or round shouldered.
When I put my 5er away, I have to back over a 6" square shoulder curb.
I end up with 2 2x6 as a base then single 2x6 then a single 2x4 to ramp up to the sidewalk height.
like this:
|2x4|
| 2x6 |
| 2x6 || 2x6 |
I reuse the 2x6's as leveling boards as I have double axels and sometimes the lynx blocks aren't enough.
All of the 2x6's came from leftover projects, but even if I had to go buy a few, they're still inexpensive compared to buying ramps or justifying a curb cut with the city plus you can make the ramps as wide as you need.
NanciL
Bakersville, NC, USA
Posted: 07/05/08 04:49am Link  |  Quote  |  Print  |  Notify Moderator
Do it the same way the construction people do it.
Use as many pieces of 2 x stuff as necessary on each side of the curb to make a smooth transition over it.
Jack L
Jack & Nanci
Wherever I happen to park
Posted: 07/05/08 07:08am Link  |  Quote  |  Print  |  Notify Moderator
I would go with a 2x4 bevel one edge to 45 degrees. if that's not enough put a 2x6 under it also bevel the "Street" edge and bolt them together, if that is not enough put a 2x8 under it (the same bolts,
And so on
donee
Simi Valley, Ca. 93063
Posted: 07/05/08 07:47am Link  |  Quote  |  Print  |  Notify Moderator
Our MH has about a six foot overhang from the rear end to the axle.
I got a pair of plastic curb ramps and they work great.
Painted the curb in a couple of places so I can hit the same spot when backing in.
05 Monaco Esquire 29PBD
05 Silver Dodge Cummins w/3.73 gears 4 spd auto.
HUTCH45
NORCAL
Posted: 07/05/08 10:58am Link  |  Quote  |  Print  |  Notify Moderator
You might get some ideas here...index on the left side of page.
'Homemade' ramps are pretty easy though as others have mentioned.
www.discountramps.com/atv-carriers.htm?gclid=COOk_dHntY0CFQoBYAodbT-GFQ
"HUTCH"
'07 SILVERADO 3500HD 'CLASSIC' DRW - CC - 4 X 4
'07 NEW HORIZONS 35' 5th.Wheel 'MotoMover'
'06 HONDA 106hp.VTX1800 w/'HANNIGAN' Sidecar
"PRIMO" The Boxer
2007dura
Hendersonville, NC
Posted: 07/05/08 12:02pm Link  |  Quote  |  Print  |  Notify Moderator
You could use the lego style leveling blocks to form an incline, or here is a curb ramp.
2007 Classic 3500HD DRW/LT3 Duramax/Allison
2008 Jayco Designer 35RLTS
salem
Central Valley, Ca
Posted: 07/05/08 07:12pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks 2007 dura, that "curb ramp" looks interesting. Think I'll give them a call and check it out. Thanks to all who replied. I don't actually have enough old 2x4's to cut up and make my own. If I had to go buy them, it'd be about as cheap to look in that "curb ramp."
donee
Posted: 07/05/08 08:45pm Link  |  Quote  |  Print  |  Notify Moderator
The ramp that 2007 posted is the same one Im using and it works very nicely.
