cl60av8tor
St. Louis
Iam having problems with my headlight on my 95 Pace arrow. The headlight s got stuck in high beams and would not dim. Now the headlights and fog lights will not work at all. I suspect the light switch. ANY HELP.
THANKS
pulsar
Lewisville, NC
Moved from Form Technical Support to Tech Issues.
2002 Adventurer 32V - Workhorse chassis
1998 CRV toad - manual transmission
Have you seen the RV.Net Blogs? You can subscribe at Blog.RV.Net
Wherever I happen to park
Well.. for starters you will need either a new headligh dimmer switch or
If your rig has relays (And I suspect it may have them) you might need new headlight relays
The reason I suspect relays starts with the phrase "Now the headlights and fog lights"
You can contact your coach manufacturer to get a wiring diagram for the headlight/foglight system
stan-2
rome GA.
my 93 Pace arrow had that problem, it was the headlight dimmer switch. I got one at the parts store mine took a 1987 chevrolet truck. I took my old one with me to match it up with one. It worked great on mine
Vulcanmars
Naples, FL
You may just have a bad headlamp. I have come across a few vehicles that automatically switch to high beams if a low beam fails. It's been a while but I am sure this system was common in 80's~90's.
Mars
06 Rage'n FA3005
04 V10 F250 SDCC 4X4
Pullrite SG 16K
1st TH 02 Keystone Tailgator
tom_kat
way upstate new york/lake george area
corroded contacks where the power wire plugs into the bulb can cause problems like that,also bad grounds.
1985 Class A Holiday Rambler Imperial 33 +1979 Class C Holiday Rambler Statesman 1000 = 24 ft
itsalleasy
If the dimmer is on the column it might even be an adjustment. Some switches are mounted lower on the column near the ignition switch and are actuated be a small rod. If the screws are loose the switch can move.
webhannet
Southern Coastal Maine
The foglamp relay and fuse are located in the black INTELLITEC box inside the front hood - the headlight items are located on the panel beneath the steering column. The problems should be unrelated.
HSIKES
Wilmington,NC
Check your relays. Fixed mine.
Horace & Bobbi
DRAKE - Yellow Lab
1996 Pace Arrow Vision
2000 Saturn LW TOAD
