RV.Net Open Roads Forum: Fifth-Wheels: skylight in the shower
 > skylight in the shower
Qtrmidget
Newborn, GA
Posted: 07/05/08 11:46am Link  |  Quote  |  Print  |  Notify Moderator
Wadcutter,
Could you post some pic's if you have them of how you did the j-channels???
Would love to see it.
Pam
Jimmie & Pam &
18 Year old Son(Dakota)& his friends
Tazz (Spoiled Rotten Toy Poodle)
Ditto Blk Lab-non camper
Jagger Qtr Horse-non camper
Partner Qtr Horse-non camper
2004 Open Road 360RKDS
2006 F-350 PSD CC King Ranch FX4
KSadler1
Albuquerque, NM
Posted: 07/05/08 12:11pm Link  |  Quote  |  Print  |  Notify Moderator
Airstreamer67 wrote:
I cut a piece of lightweight plastic-like material and put velcro on it and the edges of the skylight. It can be removed easily and works well.
I tried that with a piece of light cardboard but every time I went to check on the 5er (in storage) the cardboard was on the shower floor. I used velcro but when the sun heated up the sticky backing it just fell off. I think I'll see if I can find one of those wire rimmed car window shades. It won't fit perfect but it might just have enough tension to stay in the opening.....
Ken
Crodad
Lafayette, LA
Posted: 07/05/08 01:47pm Link  |  Quote  |  Print  |  Notify Moderator
frank henn wrote:
We got the vent insulated inserts from CW works great
Ditto
2008 F-250 PSD 4x2 Lariat
2005 Keystone Laredo 29RK
restlesswind
Fulltime
Posted: 07/05/08 02:47pm Link  |  Quote  |  Print  |  Notify Moderator
We bought some foam seat cushions from WalMart,cut some bubble foil to fit,stuck them the in the openings (from the inside),works very well.We use them also when the trailer is sitting in the sun,they help to keep the air conditioner from working so hard. We also put the bubble foil in the windows that are on the sun side.
Hichhiker DA
04.5 Dodge TD SRW
Fulltimers
KSadler1
Albuquerque, NM
Posted: 07/05/08 03:02pm Link  |  Quote  |  Print  |  Notify Moderator
Do they carry various sizes? I went to their site and saw the ones for the 14x14 vents but the skylights in the shower are much bigger. I guess you could just buy 2 of the smaller ones and use both on the larger skylight?.....
Ken
BamaMac
Alabama
Posted: 07/05/08 03:10pm Link  |  Quote  |  Print  |  Notify Moderator
Our Montego Bay is an '07 model, we had the same complaint and noticed that for '08 KZ made a tinted skylight standard. We thought about replacing it, but there is some benefit in having the sun in the shower occasionally to kill molds.
In the meanwhile I have taken the smallest size 3m brand "Command" hooks (these are clear) and attached them (6) to the trim around the skylight opening, with the open end of the hooks facing inward. Then, I cut piece of bubble-insulation to fit the opening, and the "hooks" hold it in place. The Command hooks hold better than Velcro, and we can put the cover in or take it out as we wish.
Works for us.
Kodiak5er
Alex Bay NY Summer; Sanford FL Winter
Posted: 07/05/08 03:25pm Link  |  Quote  |  Print  |  Notify Moderator
My Newmar came from the factory with a shade already installed on the shower skylight. The shade is just like the pleated window day/night blinds except it is mounted under the skylight.
1990 6500 Chevy Kodiak, 8.3L Cummins 450 HP
6sp Allison 3060, 3.70 R/A Home Made Air Ride
2006 Newmar Cypress
Picture of '93 Mountain Aire Story of it's death by fire and explosion
sirdrakejr
Las Vegas, Nevada
Posted: 07/05/08 03:56pm Link  |  Quote  |  Print  |  Notify Moderator
Velcro, glue and the double sided aluminized bubble reflector will fix that for you quickly if you are a handy guy.
Frank
RV.net blog
For those of you looking for expert advice, here ya go!
Frank
Dutch & Di
Livingston, TX
Posted: 07/05/08 08:21pm Link  |  Quote  |  Print  |  Notify Moderator
Our Carriage came with a pull shade which gives us the best of both worlds. It is a dark tan color and does keep it relativey dark. If an RV supply store an't help, you might try the blind section of say Home Depot or Lowes. If you have your inside measurements with you,you might just find what you need there. Diana
1996 1 ton Dodge Dually , Jordan Ultima Brake Controller, Mor/Ryde Suspension Rear Springs, Air Bags, Tailgate Easylift
1996 Tripple Slide Carriage, Mor/Ryde Suspension, Kodiak Disc Brakes, Power Plus Automatic Leveling System, Plug It Right Stabilizers
Wadcutter
IL
Posted: 07/05/08 08:44pm Link  |  Quote  |  Print  |  Notify Moderator
Qtrmidget wrote:
Wadcutter,
Pam
Sure, no problem but it will not be for a week. I'm not where my 5er is at the current time. Will be getting back to it in a few days.
Camped in every state but Alaska
