RV.Net Open Roads Forum: Beginning RVing: Sewer/fittings question
 > Sewer/fittings question
TCandDC
Anaheim, CA
Posted: 07/05/08 06:13am Link  |  Quote  |  Print  |  Notify Moderator
I noticed with our new Discovery Motor Home there are a lot of various fittings that came with the sewer drain hose. Some are self explanatory while others are not. My question is as follows:
Do all Campgrounds with hook ups and/or dump stations have the same connection on their end (the ground end where we connect to) or do they vary from place to place?
Thank You....Tim
Visit my Nature and Wildlife Photo Gallery at:
http://www.socalt.com
Polishnurse
Schodack, NY
Posted: 07/05/08 06:25am Link  |  Quote  |  Print  |  Notify Moderator
Very, like they say life is like a box of chocolates, you don't what your going get. Bill
Dick_B
Palos Heights, IL USA
Posted: 07/05/08 06:59am Link  |  Quote  |  Print  |  Notify Moderator
A lot of campgrounds have gone to PVC (white plastic) sewer connections which, I think, are 4 inch diameter.
If you get ahold of a Camping World catalog you will see all of the fittings they have for sale to give you an idea how to use each one.
Hopefully, they also included a rubber `donut' to seal the connection at the campgrounds sewer pipe.
Dick_B
2003 SunnyBrook 27FKS
2003 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
NCHornet1
Mt. Airy, NC.
Posted: 07/05/08 07:12am Link  |  Quote  |  Print  |  Notify Moderator
As long as you have the cone shaped adaptor with different threaded steps to it and a rubber doghnut you should be set for all cg's.
NCH
2000 Ford F350 4X4 PSD,CC, DRW
4:10's, BTM Muffler, Isspro Gauges,
Coolant Filter,CCV Mod
FTVB , Ford AIS
6.0 Cooler,SCT2 W/DP's 40 tow & 80 econo,Zoodad mod
2005 Keystone Hornet 30BHSS
Reese Dual Cam
Family of 4 saved by Grace!!!
MY TRUCK
OUR TRAILER
yardmaster
Levittown, PA
Posted: 07/05/08 07:23am Link  |  Quote  |  Print  |  Notify Moderator
NCH
I've been curious about those "threaded steps"....if the hole in the ground isnt threaded...why bother with threads???
Scott B.
1986 Fleetwood Wilderness 23S
2004 Chevy Silverado 1500 - Cowboy Cadillac
PattieAM
Maryland
Posted: 07/05/08 07:53am Link  |  Quote  |  Print  |  Notify Moderator
I have a variety of fittings for my sewer hose, and several hoses. I particularly like my 'complete' hose with it's fittings, and when at a campground with an unthreaded sewer inlet, I can still use this hose/fitting, but secure it with a rock so it doesn't pop out of the sewer inlet when I open the valves.
rockhillmanor
On the Road
Posted: 07/05/08 09:41am Link  |  Quote  |  Print  |  Notify Moderator
yardmaster wrote:
NCH
Most CG's have gone to the threaded pipes. But they work on non threaded pipes just as well.
Trust me just sticking the threaded cap into one of these non threaded sewer hole pipes DOES make a difference in keeping the sewer gas from spreading all over like it would if you just stuck the sewer hose in it.
The State Fair Grounds in Florida does not require a fitted cap on sewer hoses you just stuck the sewer hose in the pipe and boy did it stink in the CG area, you could hardly breath.
31 ft Four Winds
Chevy Tracker 4x4 Blue Ox
We must be willing to get rid of the life we've planned,
so as to have the life that is waiting for us.
TCandDC
Anaheim, CA
Posted: 07/05/08 10:10am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the help. I guess they gave me everything but that DONUT. I will upgrade and get it set up properly now based on the info you all gave me here....Thanks.
Wherever I happen to park
Posted: 07/05/08 01:56pm Link  |  Quote  |  Print  |  Notify Moderator
The short answer to your question is NO
Some have threaded fittins... Different sizes, too
Some just have "Push in"
Some .. Well, let's just say there are many options
NCHornet1
Mt. Airy, NC.
Posted: 07/05/08 03:04pm Link  |  Quote  |  Print  |  Notify Moderator
yardmaster wrote:
NCH
If it isn't threaded that is what the Doughnut is for!!! Either that or stick it in the pipe and put one of those straps over it, or put a rock on it. I would rather seal it as tight as possible for my sake and the sake of my neighbors. Wish everyone was as considerate!!
NCH
