NCHornet1 wrote: As long as you have the cone shaped adaptor with different threaded steps to it and a rubber doghnut you should be set for all cg's.
NCH
I've been curious about those "threaded steps"....if the hole in the ground isnt threaded...why bother with threads???
I have the threaded adapter and if there are no threads I just put the threaded in into the pipe and then I carry two bricks and tie a string around the each and the wrap the string around the threaded adapter and roll the brick up around an string left over do I weight the fitting down with the two bricks.
Larry
2001 standard box 7.3L E-350 PSD Van with 4.10 rear and 2007 Holiday Rambler Aluma-Lite 8306S Been RV'ing since 1974. TRAILER MODS
From what I've read around here, some states require that rubber donut. Your campground should have it posted if it is required. You can pick them up at any RV store and even at Wallyworld.
edited 07/05/08 10:25pm by wny_pat *
If it isn't threaded that is what the Doughnut is for!!! Either that or stick it in the pipe and put one of those straps over it, or put a rock on it. I would rather seal it as tight as possible for my sake and the sake of my neighbors. Wish everyone was as considerate!!
AMEN!!
Just because a doughnut is not "required" is no reason not to seal the pipe properly.
