devenhaven
western n.c.
Just purchased this unit and already have issues. It has a onan 7k generator, it cranks fine but when i turn on the main a/c, it runs for about 2 minutes then turns off, (generator and the a/c). I switched the ref. to gas and the a/c will run on low but that is it. Also, when i run the dash a/c the belt whines loud then quits and ever so often whines again. Does it need a new belt or belt dressing? We camped with the unit and on shore power every thing went fine. But with a longer trip planned later, shouldn't the generator be able to run the unit a/c, ref, and lights and tv while traveling down the road????? This is my first rv and any help and suggestions are greatly appreciated. Also, i have no owners manual for the unit, is there a website or place that i might be able to purchase one????
radardog
delaware
There is a winter/summer lever on the generator, see if it is flipped to winter setting. Also check the oil level and try changing the oil and filter. Make sure the gas gauge reads over 1/4 tank or it may be running the generator out of gas. If the 1/4 tank is at the right level the gen will start run a minute then shut down. I had a 93 Vectra liked the unit.
The fan always wins
tomlang
Los Angeles area
Here's the link to Winnebago's site where you can download the Winnebago brochure:
http://www.winnebagoind.com/products/pre........ls/1996/pdfs/vectra/1996Vectralowres.pdf
Owner's manuals for motorhomes are pretty generic. You probably need to go to the website for systems (like the Onan generator) to find manuals. Generally, they are all available for free download.
Tom and Lynne
Tom is an Electronics Engineer, Lynne a retired teacher.
old rig is a 1988 Winnebago Superchief, currently on tour with the Blue Turtle Seduction (band)
new rig is a 2003 Foretravel 38' U295
devenhaven
western n.c.
I filled the gas tank, but i'll check the switch on the generator. thanks for the tip. As far as changing the oil, do auto parts store carry the filter and what kind and how much oil should i need????
Economical Handyman
S. California
Gas or diesel ?
DeWayne & Judy
04 3810 Dutch Star
ISL 370
Frank's autoformer
01 Sahara Jeep-toad
F 374382
It is hard to kiss the lips at night, that has chewed your butt all day long!
devenhaven
western n.c.
Thanks for the link, I'm printing it now.
devenhaven
western n.c.
Gas
