RV.Net Open Roads Forum: Tech Issues: Electric to Disc brake conversion
 > Electric to Disc brake conversion
facory
Mineral Bluff, GA
Posted: 07/05/08 10:24am Link  |  Quote  |  Print  |  Notify Moderator
We have a travel trailer with the typical electric brakes. They seem to work very well. However, I am seeing disc brake conversions featured on TV lately. They claim that electric brakes are not reliable and too hard to keep 'tuned' so that all four wheels brake the same.
So far in our travels the TV has been able to hold the trailer back sufficiently by downshifting so that the brakes do not get over heated.
Has anyone done a conversion to disc brakes, and if so, does it make sense?? What is the cost including labor?
Fred Cory
Mineral Bluff, GA
2008 20' Cruiser RV Toy Hauler
Dodge Durango 5.9L
Harley 06 VRod
Peg Leg
Anderson, IN
Posted: 07/05/08 10:50am Link  |  Quote  |  Print  |  Notify Moderator
I looked into to disc brakes years ago. The cost seemed to high for replacing something that already worked. I can replace the entire elec brake assembly, backer plates with shoes, springs, magnets for about $40 each. 4 nuts and cut 2 wires, splice the new magnet wires and replace the 4 nuts, easy as pie.
Just adjust the brakes at the start of the season or before a long trip. Might take between 1 to 2 hours tops, from dragging out the tools and putting them up when done.
KA9ATV
K2500 7.4 3.73
Michelin 245/70R19.5 XDS2 on Vision Type 81's
31' Dutchmen
Yamaha EF3000iSE
retired gadgetman
Vulcanmars
Naples, FL
Posted: 07/05/08 11:49am Link  |  Quote  |  Print  |  Notify Moderator
I'll 2nd that. Electric is clean, simple, and cheap to replace.
Mars
06 Rage'n FA3005
04 V10 F250 SDCC 4X4
Pullrite SG 16K
1st TH 02 Keystone Tailgator
Golden_HVAC
Fulltime, CA, USA
Posted: 07/05/08 12:00pm Link  |  Quote  |  Print  |  Notify Moderator
Hi,
You have a "Small" and "Light" trailer. So a disk brake conversion is not really going to change things in your situation. However if the trailer was a 16,000 pound fifth wheel, a disk brake conversion would be a better canidate. That is because a really heavy fifth wheel can overload it's drum braking system - especially on long downgrades found out west.
Here is a place that sells the parts for both repair of your drum brakes and disk brake conversions. ETrailerPart.com
If you have ever taken apart the brake drums, you will notice that they only work when going forward. While backing is done at low speeds, remember that the brake drums can only release while backing up. It just has to do with the way the magnets are installed.
Fred.
Money can't buy happiness but somehow it's more comfortable to cry in a Porsche or Country Coach!
If there's a WILL, I want to be in it!
Improve a life KangenPowerTeam.com Akaline Water.
I havn't been everywhere, but it's on my list.
Escapees.com
Wherever I happen to park
Posted: 07/05/08 01:24pm Link  |  Quote  |  Print  |  Notify Moderator
Let me ask a question:
Are your existing brakes working properly, Do you have any complaints about them?
NO,,, YES
Now your question slightly reworded
Should I convert from my existing drum brake system to a disc brake system?
Well.. Same answer to both questions
No problmes.. no convert
facory
Mineral Bluff, GA
Posted: 07/05/08 02:06pm Link  |  Quote  |  Print  |  Notify Moderator
Good comments and thoughts. Thanks all. No problems with electric brakes..yet. I'm just the kind of guy who always looks for 'something better' if it's out there.
mike4947
N. Syracuse, NY
Posted: 07/05/08 02:48pm Link  |  Quote  |  Print  |  Notify Moderator
Like Bearing Buddies, and surge brakes, the disk brake conversions and new installations were meant for the boating folks. There's a limited market so they try and convince RV'ers that disc are worth the expense of retrofitting.
Like Fred mentioned there may be some value for a heavy trailer, but the more than a thousand dollar investment won't add much otherwise unless you use your trailer for launching boats.
blog.rv.net Your daily guide to the Open Road
Subscribe to the daily digest
Want to sell some of your gear? -
Free Classified Listings on RV.Net
They say you learn by your mistakes, in that case I must be a genius.
Fulltimer50
On The Road
Posted: 07/05/08 05:33pm Link  |  Quote  |  Print  |  Notify Moderator
How do you come up with the idea that disk brakes are for boat trailers?
George
99F250XLT/SC/LB/4x2/3.73LS/gauges/JNB BypassReg/ Airlifts/Rancho 9000s/DS Predator Tuner/203*TS/Coolant filter/Jimmyjammers/Oilguard/4"turbo back/Suncoast tranny/BD EBrake.
06 Newmar Cypress 29KSRE 5th wheel, Mor/Ryde IS, Kodiac disk brakes
