RV.Net Open Roads Forum: Beginning RVing: leveling a triple axle
 > leveling a triple axle
davelinde
Freehold, New Jersey
Posted: 07/05/08 11:43am Link  |  Quote  |  Print  |  Notify Moderator
Next week we pick up a new triple axle TH. I only have two Levelair bags and I don't think they are sold any longer so I was wondering if it's OK to just level two of the three axles on our new rig? If so, which two?
While I'm posting... anything else I need to consider wrt to having 3 axles?
Dave Lindemulder
Tammy, Mark & Kirsten
04 Dodge 2500 4x4 SLT QC/SB
HO-CTD/48RE - Graphite: Raptor SS nerfs, Prodigy, Reese 16K Kwik-slide, BD X-Monitor, PML Trans pan, PML Diff cover, Firestone Airbags
09 Heartland Cyclone 3210
NCHornet1
Mt. Airy, NC.
Posted: 07/05/08 12:13pm Link  |  Quote  |  Print  |  Notify Moderator
NO you want each axle to carry the same amount of weight. I too have the levelairs and wouldn't live without them. Check Ebay I have seen them on sale before or make your own, there are directions on this site. Guy told me he was going to be back in business after he got a patent issue worked out, but that was well over a year ago. It's a shame as he built a wonderful product and is a heck of a nice fella.
NCH
2000 Ford F350 4X4 PSD,CC, DRW
4:10's, BTM Muffler, Isspro Gauges,
Coolant Filter,CCV Mod
FTVB , Ford AIS
6.0 Cooler,SCT2 W/DP's 40 tow & 80 econo,Zoodad mod
2005 Keystone Hornet 30BHSS
Reese Dual Cam
Family of 4 saved by Grace!!!
MY TRUCK
OUR TRAILER
Golden_HVAC
Fulltime, CA, USA
Posted: 07/05/08 12:17pm Link  |  Quote  |  Print  |  Notify Moderator
Hi,
With a normal two axle fifth wheel or travel trailer it does not matter what axle you raise. The same is true for your fifth wheel. There is a linkage between each axle to distribute the weight equally.
Fred.
Money can't buy happiness but somehow it's more comfortable to cry in a Porsche or Country Coach!
If there's a WILL, I want to be in it!
Improve a life KangenPowerTeam.com Akaline Water.
I havn't been everywhere, but it's on my list.
Escapees.com
VernM
Marion County, AR
Posted: 07/05/08 02:01pm Link  |  Quote  |  Print  |  Notify Moderator
You put all the weight on less than all three wheels on that side and you likely are loading those fewer wheels to more than their structure is designed for. Save yourself a headache later, Prop up all three equally.
Fred, it isn't the linkage that will get the load with dissimilar lifting, it is the tire(s) and wheel(s).
VernM
GMC Conversion van/Wells Cargo MiniWagon trailer
Sent via HughesNet/SatMex5 Internet Portal
samsontdog
Sac. Ca summer, Yuma Az winter
Posted: 07/05/08 02:26pm Link  |  Quote  |  Print  |  Notify Moderator
I would defiantly level all axles . You can use blocks of wood to drive upon.
samsontdog
davelinde
Posted: 07/05/08 04:53pm Link  |  Quote  |  Print  |  Notify Moderator
VernM wrote:
...it isn't the linkage that will get the load with dissimilar lifting, it is the tire(s) and wheel(s).
I'm quite sure the tires and wheels can handle the static loading even if I lifted the third wheel clear off the ground. I'm not quite so sure what it would do to the frame and other parts though - or if there's something I'm not thinking about here.
VernM
Marion County, AR
Posted: 07/05/08 06:42pm Link  |  Quote  |  Print  |  Notify Moderator
Gravity is what you are working against. Trying to support the load on anything less than what it is designed to be supported by is putting a heavier load on what touches the support.
As to twisting the frame, etc., it is less likely but you'll notice it first in closing or opening the trailer door. If that binds, you're in trouble. With a conventional trailer, you can ease some of that with the corner jacks. Not so easy with a 5th wheel.
