RV.Net Open Roads Forum: Leaving 5er connected to house power with no load
 > Leaving 5er connected to house power with no load
5erTrailerTrash
Anchorage, Alaska
Posted: 07/06/08 03:44pm Link  |  Quote  |  Print  |  Notify Moderator
I keep mine plugged in all winter because I run an oil-filled radiant heater and a dehumidifier. I haven't had any problems.
magnumiii
FL
Posted: 07/06/08 07:01pm Link  |  Quote  |  Print  |  Notify Moderator
I would get the battery that is bubbling and has an order coming from it tested. That usually indicates a bad battery. I keep mine plugged in all the time and have not had a problem, just keep an eye on the water level about every 4 to 6 weeks
2007 Ford F250 Super Duty Crewcab PSD
2007 KZ Durango 285RL 5ver
pdinaj
Apache Junction,Arizona
Posted: 07/07/08 04:59am Link  |  Quote  |  Print  |  Notify Moderator
The answer to your question is simply, NO.
smkettner
Posted: 07/07/08 09:57am Link  |  Quote  |  Print  |  Notify Moderator
Bubbling battery is probably either weak or has a shorted cell.
Time for at least one battery.
Check the float voltage and post the make/model of the converter for better info.
mapguy
Puget Sound
Posted: 07/07/08 11:28am Link  |  Quote  |  Print  |  Notify Moderator
Outback should have a WFCO if a 2006 model. Always recharge batteries fully before storage to maximize lifetime. Batteries will out-gas and require periodic addition of distilled water -even with a three stage charger like the WFCO. Especially if deeply discharged before charging. You have some indications of a failing battery. Sounds like a load test is in order after fully charging.
Map Guy
