Well the little lever on the commode like to stick open. Filling up the tank and eventually into the trailer. I forgot to tell out company the second time before we went to bed. I awakened in the middle of the night to a waterfall in the bathroom.
So questions would be what is problem with the toilet not closing all the way? Is there a spring that should pull this back closed that has weekend?
Each time it flooded from the commode down under the fridge on past the water heater/furnace, up to the front of the trailer. It drained out through the little seams that goes down the trailer. I immediately took all panels I could out each time and put fans blowing on it. Should I be concerned with my floor rotting now?
I would have given that toilet the deep 6 after the first time. I learned the hard way that a new toilet is cheap enough to simply replace it rather than fight with a problem one.
Dixonmatco wrote: I would have given that toilet the deep 6 after the first time. I learned the hard way that a new toilet is cheap enough to simply replace it rather than fight with a problem one.
YEP! Dump the thing and get a new one.
08 Camelot
07 Ranger Toad
One lost Golden Retriever
I don't think you need a new commode!!! You need to investigate the valve, it may just need some lube, I assume there would be a return spring or something to close the valve and reset the pedal. If you are mechanically inclined this should be easy. If you can give me the make and model number by Pm I can probably find a schematic of it and tell you what the problem is.
NCH
2000 Ford F350 4X4 PSD,CC, DRW
4:10's, BTM Muffler, Isspro Gauges,
Coolant Filter,CCV Mod
FTVB , Ford AIS
6.0 Cooler,SCT2 W/DP's 40 tow & 80 econo,Zoodad mod
2005 Keystone Hornet 30BHSS
Reese Dual Cam
Family of 4 saved by Grace!!! MY TRUCK OUR TRAILER
those toilets are only plastic, and if not evenly torqued down, they can warp, causing the slide valve to bind. had the same problem on two class a's.
1999 F-250 Extra Cab SD 4X4 V-10
2000 Wildwood 28RKSS2S 31' 5ver
Derrick, Michelle, Michaela, Riona and "Bones" (K-9 companion) We Are Currently Here my website
Well, since no one else answered you question about rot, I will try, but I am a noobie at this. I would say, yes you need to worry about rot. At the same time, I would say no b/c you put fans in and I am assuming mopped it up and got it dry. I would pull up any flooring and check it
2007 Nissan Titan Off-Road w/ leveling kit---THIS THING IS A PIECE OF JUNK
2008 Jayco Jayflight 28BHS
Me, wife, one little girl and one little boy
all along for the ride.
No I wouldn’t worry to about rot in the floor from this. With the temps were they are now and as long as you mopped up the main water and put fans in the affected areas you should be fine.
Now on to the toilet, I would think all you need is a new valve. You didn’t say what kind of TT you have or what brand toilet is in it.
I agree you need a new toilet. As in the new toilet that comes in a new TT. Will the floors rot out? LIKELY they will. But more importantly is the MOLD!!!! This flooding may or may not cause mold, but if it does, its there to stay UNTIL you replace the flooring
Tim-DW(Kathy)-DS(KEN)
04 AVEO-DD, 03 JEEP GRAND CHEROKEE, 94 Firebird(da toy) 07 COACHMEN SOA 32FKS(stress relief center) If Im not at the CG---I'll be somewhere else! Total nights camped in 07 = 62
