Gary3
Windsor, ON
Have any of you Lance owners built a cover for your Hyki hatch while your not using the camper. I was trying to think of something to keep the heat out since your not supposed to close the shade when that sun is blazing.
Gary Lance 1181 solar Gen.
F350OilBurner
Central MA
You can buy covers, spoilers, gaskets, parts, etc. for the Dometic Heki vent from this place. The only problem is they are in the UK. I can't find any place in the US that stocks this stuff. Nor do I know if they ship internationally. But it's worth a shot. Let us know what they say if you decide to contact them.
2006 Ford F350 Lariat CC LB DRW
6.0 PSD w/TorqShift 4x4 4.10LSD
Airlift Airbags/SureSet Controller - Timbrens
2007 Lance 1181 - All the Options
Torklift Superhitch/Tiedowns/Fastguns
Gary3
Windsor, ON
I recieved a reply from Leisure products they want 7.75 pounds for delivery and it looks like 23 for the cover.I,m thinking a pound is almost $2 US so that would be $61.50 . They measure in mm even being Canadian I,d have to do some figuring. It shows a 700mm one and another large, if anyone knows what size is on the 2008 Lance it would save some time.
Americamper
Anniston AL
I was thinking about making a cover and maybe velcroing it on or something myself.
2000 F250 Superduty 7.3 SB SRW, E rated Michelins, Torklifts, fastguns,2004 Northstar Laredo, 2005 Americamp 5'er, Triumph Tiger 1050, Yamaha YZ450
jmcgsd
San Diego, CA
Do you mean the large hatch over the bed?
If so, my 981 is 3 years old, and I live in a desert climate. I have never done anything special and at least the one on my '05 is still performing just fine. If there is anything in my owner's manual that says there could be a problem I've never read it.
'05 Lance 981Max Loaded
'91 F350 Dually 2WD CC 460 Gasser
AirLift Bags, Reese Titan hitch, Rancho 9000X
Banks TransCommand
'87 Suzuki Samurai Toad
1 DW
My Camping Web Page
Heavy_Hauler
Carlsbad
Gary3 wrote: I was trying to think of something to keep the heat out since your not supposed to close the shade when that sun is blazing.
Read your manual a little closer. Your not supposed to "completely" close the shade. Leaving it open a crack, say 1/2 inch will be just fine. Save your self $60. I have 2 years experience in temperatures up to 110 degrees on this one. ..Mike
2004 GMC Sierra 3500 4x4 D/A EC LB DRW
Ride-Rites, RS9000X, TorkLift, Fast Guns, Superhitch
2007 Lance Max 1181
kehale
Texas 2007
I'm living on the edge.
I cut some reflectix insulation and cover the inside. I leave the shade open about 3".
2 years, no problems yet (temps up to 108)
I thought maybe the lens would crack, but....nope.
The insulation sure helps the AC.
06 Lance 1181 on heavy duty Ford pickup
Gary3
Windsor, ON
I think if a person put the reflective up against the dome it would be alright because the heat can,t build up and make the plastic arm brittle.What I did for now is made a cover out of a cloth agains the dome then a piece of I call it bubble foil over that then white ducttape holding it on. This is on the outside and it looks alright.Thats what Jim Allan said to try, he said the problem they had was people would shut that shade in the summer and the heat buildup would cause the arm to go brittle and break.Its to bad getting one of those hatch covers is so complicated ( comes from UK).
