lhamblin
Surrey BC
Does any blogger have any reccomendation on RV Battery Watering Filler Kits that they have installed on their coaches?
JUrban
Delaware
We got ours at Camping World, and when we got a new coach, got another. Wouldn't be without it.
John
2008 Tiffin Allegro Bus 40' QSP
2006 Chevrolet Colorado Toad
BlueOx Aventa LX Tow Bar
SMI Air Force One toad brake
Copilot Live Laptop 10 GPS
pulsar
Lewisville, NC
Moved from Forum Technical Support to Tech Issues.
2002 Adventurer 32V - Workhorse chassis
1998 CRV toad - manual transmission
Have you seen the RV.Net Blogs? You can subscribe at Blog.RV.Net
aslakson
Fulltiming in the Lower 48
Bought ours at "The Rally" this spring - both for chassis and house batteries. Now I actually keep the batteries watered. Spendy but worth it.
al
Serena
US
I had intended to get one of these systems. But then I got a kid's sippy cup, a plastic funnel, and an LED clip-on light from the dollar store and decided the extra expense didn't really make any sense after all. Clipping the little light onto the the battery housing cover or the brim of a ballcap gives me a clear view of each cell so I don't overfill, and the sippy cup gives me very precise control.
So I'm down a whole 3 bucks, and all the batts are 100% happy. YMMV, of course.
Serena
I Know Where I Been, Cuz I Was There When I Went.
ryanallie1
Magalia, Calif
Hi All.
We have had the "Battery Fill System" ever since they first came out. Our 5er, was built to only carry two Group 24 Deep Cycle Batters. They were stacked, and very hard to get to. As you had to pull each battery almost completely out of the compartment to even be able to check the water level. But since two Group 24's are pretty limited to the Battery Reserve Time, we decided to put two Group 27 Deep Cycle Battries in their place. You want to talk about a very tight fit now. We only half a 1/2 inch clearance for each battery on the top, and a inch or two on each side. The Group 27's weight a lot more, than the group 24's. Each Group 27 Deep Cycle Battery weights in at 85 pds each. There is no way to pull most of the battery out to even try to check the water level. Unless two people do it. What I use to do, was to use a step stool, and a step ladder, with 2X6's across both, in order to pull the batteries out, in order to pull the battery caps to check them. Now checking water levels in the Battries is now something of the past. With a Good Smart Three Stage Intell Converter/Charger, with the Charge Wizard, and the Battery Fill System, we now only have to give the bulb a squeeze maybe once or twice a year now. And even then, it usually only takes less than one once of Distilled Water between both group 27's. We also leave our 5er plugged in 24/7 when we are not using it. If your batteries are as hard to get to as ours, and heavy battries also, then the price of the Battery Filler Kit, is money well spent. We would buy the "Battery Fill System" again, at any price. It sure has made our lives a lot easier. We will never own another RV with-out the "Battery Fill System" Good Luck. Happy Camping. Dan & Jill
1997 Ford F-250, H.D. Extended-Cab, Short Bed, 7.3 PSD, K&N Air Filter, 5000 lbs air bags w/on board compressor w/guage, SuperChips Tuner/Programer. 1996 Nash 24fter 5er, 15K "Lil" Rocker Hitch w/BedSaver, Twin EU2000i Gen's W/Kit. Nam-Vet, 33 Months.
maxum1989
Vancouver Canada
How do these battery watering systems work? You just squeeze the ball and it just knows how much water to add if necessary? How does it not add too much? I too have batteries that are very hard to get at so they get neglected as a result. This seems like a good investment if it works as easy as it sounds.
JUrban
Delaware
There's a float in each unit that replaces the battery cap. When that cell is full, it cuts off. You keep squeezing the bulb until all of a sudden it gets very hard. All full. There's a quick disconnect to the system that pulls off, you drain the distilled water back to the container, and you're done.
John
Dave H M
IL
whoah, I am gonna keep the turkey baster out of sight.
maxum1989
Vancouver Canada
Thank you. This is now on my wish list to buy over the next short while.
