RV.Net Open Roads Forum: Tech Issues: Using 220 electric
 > Using 220 electric
ronandln
Rancho Cucamonga, CA
Posted: 07/06/08 02:08am Link  |  Quote  |  Print  |  Notify Moderator
I have a 220 outlet in my garage. Can I use it with an adapter for my 50 volt RV?
32dgrz
Iowa
Posted: 07/06/08 03:39am Link  |  Quote  |  Print  |  Notify Moderator
http://www.myrv.us/electric/
Roadpilot
Lakes Region of New Hampshire
Posted: 07/06/08 05:58am Link  |  Quote  |  Print  |  Notify Moderator
No.
2007 Newmar Essex 45'
2006 Honda CR-V and 2005 Chevy Silverado 1500
2004 HD Electra Glide Ultra Classic
2006 HD Heritage Softail Classic
Overbilt Lift
PapPappy
Wilmington, NC
Posted: 07/06/08 06:02am Link  |  Quote  |  Print  |  Notify Moderator
32dgrz posted an excellent site.
My advice, is to get an expert. If you don't know the difference between "50 volts" and 50 Amp service, you shouldn't be playing with electricity, or your wife will be selling your RV as part of your estate before too long....know what I mean?
If that was just a typo...hey, we all do them.....then just follow the information in the above post. It is very accurate, and simple to understand.
Just remember, just because you have 220 volts in your garage, doesn't mean that it's a 50 Amp service...and more than likely, it isn't. What size is the breaker?
Again, it would make sense to have an Electrician check things out.
DH Bill / DW Claudia / DD Jenn / DS Chris
The Paps! Sophie, Abby, Brandy, Kahlie and Annie
Purchased April Fools Day, 2008
The Pets
wayne_tw
South Dakota/Georgia
Posted: 07/06/08 06:05am Link  |  Quote  |  Print  |  Notify Moderator
You do not have 220 electric in your garage and you do not have a 50 volt RV.
You may have a 240 volt outlet in your garage and you may have a 50 amp electric service RV.
I say MAY, because with your wrong use of terminology, you probably have little understanding of electricity and may well cause damage to the components of your RV if you plug into the wrong electric supply.
A 50 amp RV is wired to accept 240 volt electric service.
IT would be uncommon to have a 240 volt electric supply already wired in the garage, but certainly very posible.
Make sure that the outlet is correctly wired and properly matches the plug on the RV.
david_42
Oregon
Posted: 07/06/08 07:56am Link  |  Quote  |  Print  |  Notify Moderator
If the outlet was designed for an electric dryer, it is probably only 30 amps @ 220 (or 208 or 240, depending on the area). Have an professional look at it. You would be able to use it, but you wouldn't have all of the power you are used to from a 50 amp service.
I doubt if it would cost you more than $6-700 for a true 50/220 service.
scbwr
Wilson NY
Posted: 07/06/08 08:17am Link  |  Quote  |  Print  |  Notify Moderator
ronandin...........is the outlet in your garage the type that you would use with an electric dryer? That may help clarify the question.........which I don't have an answer. From what I've seen, the pin configuration won't match....so you would need either an adapter or have a new outlet installed.
As already stated....be very careful. If you're not sure of what you are doing, bring in a professional and make sure it is done correctly. If the pro screws up, you can recover your damages if you blow out your converter, or start a fire, or worse!
2001 Dodge 3500 DRW V10 Magnum
2002 Sunline T280SR
Arrow Hensley Hitch
10' Porta Bote
My photo galleries.
answerswillvary
eastern washington
Posted: 07/06/08 08:28am Link  |  Quote  |  Print  |  Notify Moderator
Moved from Campgrounds, Resorts and Attractions
Check out the RV.NET BLOGS at blog.rv.net
pete42
Jamestown, Ohio
Posted: 07/06/08 08:43am Link  |  Quote  |  Print  |  Notify Moderator
Ron the link "32dgrz" gave is the most helpful.
Forget the others answers including mine, we know you meant 50 amps.
PETE
smkettner
Posted: 07/06/08 10:32am Link  |  Quote  |  Print  |  Notify Moderator
Read the link at the top left on welder service for the conversion to 120.
