deee2
Sparks, Nevada USA
We just got a new Ford truck, and hubby wants to change from the slider hitch he has. We're towing a 14,000 trailer if maxed, any suggestions? It's a long bed.
Steve & Donna
2009 Bighorn 3055rl
2008 Ford 350 4x4 DRW
Diesel, Tow Boss
kennethwooster
Perryton Tx USA
I loved my 20K Reese. Had to trade to a Super glide due to short bed, which of course you will not need. If you are going to be taking the hitch out, you may want to look at something different from the Reese, as it left two rails in the bed. I like the super glide as it leaves nothing in the bed. A lot of people love the B&W, I believe that is the brand. You might look into it. I bet you will get a lot of opinions. Buy quality, and I'm sure you will be happy. Pullright seems to be top quality.
kenneth wooster- farmer
wife Diana-adult probation officer
365BSQS Quad slide 2007 Quantum
Ford F350 2005 model, 4X4 FX, King Ranch
18K SuperGlide Hitch
Butch50
Roseburg (not for much longer), OR
I have 2 PullRites. One is a 20.5K Super 5th and the other is 18K SuperGlide. They are both installed with the Pull Rite super rails. Take the hitch out and remove the rails and just 4 holes left in the bed. I have had Reese and B&W in the past but prefer the Pull Rites.
This is IMO
Butch
2006 F550 CC 4X4 Lariat PSD/Torqshift Dark Shadow Grey Metalic w/Manning F350 bed
2009 Excel Limited 30TKE (Now have it)
2006 Dodge 3500 Laramie 4X4 QC SB SRW/Cummins 6 speed Jake exhaust brake
skibum98391
Seattle
I have a hijacker and love it. There really is no way to not have it hitched, if the lever is in then it is fully hitched and you will not drop your trailer. The one exception to this is if you were to high-hitch it....
Take care
Mike
CmdrDick
Chandler, AZ
Hi:
We use a gooseneck hitch which allows a completely flat deck when not hooked up. On my unit, the pin unlocks and comes out too in ten seconds. No hassles with where to store a fifth wheel hitch.
A Gooseneck adapter bolts to the fifth wheel pin on the trailer.
Installation is almost identical to a standard 5th hitch as far as the under deck portion is concerned. But when that is finished, all you can see in the deck is the small underdeck pin attach plate which is covered by a refrigerator magnet type of flat dust cover.
When I drop my RV, I immediately have 100% of my bed available, and when hooked up, I have much more deck space available because of the small size of the gooseneck.
Clean and simple and it's been doing a great job for us for many years. Numerous types and brands are available.
Miles Away
Lebanon, TN
I agree with Kenneth Woster, if you have a long bed you do not need a slider or any other fancy type of hitch, since the connection point is already far enough back to avoid collision with the cab of your truck when backing at extreme angles. If you do not want the clutter of a 5th wheel hitch in the bed of your truck when you are not towing, I would also recommend the B & W Companion Hitch or the Colibert Free Ride System, both of them are 5th wheel hitches, but are based on gooseneck systems, which allow for quick and easy removal when not in use and leave the bed of your truck clean. With regard to the recommendation that you convert to a gooseneck system, I would point out that many 5th wheel manfactures strongly frown upon this idea and may even attempt to void their warranty if damage should occur while towing in that configuration. In addition, you are not saving a lot of money this way as the cost of a gooseneck adapter, to go with the gooseneck hitch that you also have to purchase, is not a whole lot less than the cost of the 5th wheel Companion or Colibert Free Ride, which attach to the gooseneck system. Both of these systems are advertised in Trailer World and many other publications. If having a clean deck when not towing is not a worry, almost any of the American made 5th wheel hitches will work fine. Remember, with a long bed truck you will not need a slider or similar device. Good luck & happy camping.
M & M On the road again!
2007 GMC 3500-SRW-Duramax-longbed-4X4
2005 COUGAR 5th wheel
2002 SUNDOWNER gooseneck horse trailer
Charlie D.
Gonzales, La.
Be SURE that Heartland will warrant your rig before going to a gooseneck. I saw a Landmark, beautiful rig, with a loose front cap being pulled with a GN. The seams were open 3/8" to 1/2" where the front cap was attached.
Enjoying Your Freedom?
Thank A Veteran
2007 Holiday Rambler 32SKT
2006 Chev LT D/A CC
SoCalDesertRider
SanDiego, CA, USA
Using a gooseneck hitch in the truck with a fifth wheel hitch unit attatched to the gooseneck is not the same thing as using a gooseneck pinbox adaptor on a fifth wheel trailer. Go to the B&W website to find out how a gooseneck hitch can be safely used to pull any fifth wheel trailer with their Companion fifth wheel hitch attatchment.
92F350 CrewCab 4x4 351/C6
LoadNGo service body
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
B&W TurnoverBall g-neck Curt Magnum rr DrawTite ft
HD springs Rancho9000s Bilsteins poly sway bushings
4.56's & Lock-Rite rear
1414141414
East Islip
B@w hitch is the way to go
Charlie D.
Gonzales, La.
SoCalDesertRider wrote: Using a gooseneck hitch in the truck with a fifth wheel hitch unit attatched to the gooseneck is not the same thing as using a gooseneck pinbox adaptor on a fifth wheel trailer. Go to the B&W website to find out how a gooseneck hitch can be safely used to pull any fifth wheel trailer with their Companion fifth wheel hitch attatchment.
Thanks for the link. Now I understand a little better. Rig I saw had a Trailair with the inflatable donuts and a GN adapter bolted to it.
