RV.Net Open Roads Forum: Tech Issues: Portable Generator
 > Portable Generator
minkhill
Tennessee
Posted: 07/06/08 11:10am Link  |  Quote  |  Print  |  Notify Moderator
We are getting into camping in places with no hook-ups. would like some help on what a Honda EU2000 (or tandem EU2000) will run I have looked at the specs and can read them but would like to know what all will work at the same time. I have a Honda 5000 and it will run 2 TV,lights and AC all at the same time but it is way too loud. Am looking to sell it and buy 1 or maybe 2 2000's. Is anybody used them?
bldrbuck
Boulder, Colorado
Posted: 07/06/08 11:35am Link  |  Quote  |  Print  |  Notify Moderator
Check out the Yamaha inverter type also. You might like the Yamaha 3000I.
rwm2_2000
Reynolds Ga
Posted: 07/06/08 11:39am Link  |  Quote  |  Print  |  Notify Moderator
My eu2000i honda runs my entire rv except U have to cut off the ac before U use the microwave. It runs from 9 pm til 8 am running the ac but if U use a 1500 watt heater it only runs about 6 hours. If U get a eu2oooi honda generator U'll need an auxiliary gas tank unless U want to be bothered w/putting gas in during the night-especially during the winter.
ol Bombero-JC
Posted: 07/06/08 11:45am Link  |  Quote  |  Print  |  Notify Moderator
Go over to the Tech Forum* !!
Enter: "Generators" -or- "Honda Generators"
. . . . and
begin your reading assignment!
Everything you wanted to know - and MORE!
*limit your search to that forum or you will be overwhelmed!
JC
5erTrailerTrash
Anchorage, Alaska
Posted: 07/06/08 03:48pm Link  |  Quote  |  Print  |  Notify Moderator
Honda eu2000is in tandem will run an entire 30 amp RV. With a single one, you may or may not be able to run your air conditioner depending upon a lot of factors. It should run almost anything else.
sirdrakejr
Las Vegas, Nevada
Posted: 07/06/08 04:36pm Link  |  Quote  |  Print  |  Notify Moderator
Moved from 5th wheels to tech issues.
Frank
RV.net blog
For those of you looking for expert advice, here ya go!
Frank
SoCalDesertRider
SanDiego, CA, USA
Posted: 07/06/08 04:38pm Link  |  Quote  |  Print  |  Notify Moderator
I have a 4000 watt Generac that runs anything 240v up to 20 amps, including welder, plasma cutter, air compressor and RV AC. Two 2000-watt units should put out about the same.
92F350 CrewCab 4x4 351/C6
LoadNGo service body
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
B&W TurnoverBall g-neck Curt Magnum rr DrawTite ft
HD springs Rancho9000s Bilsteins poly sway bushings
4.56's & Lock-Rite rear
smkettner
Posted: 07/06/08 05:36pm Link  |  Quote  |  Print  |  Notify Moderator
If it is a 30 amp RV the two hondas will have plenty of power for everything you normally run.
sctusa
Davie, Fl.
Posted: 07/07/08 04:55am Link  |  Quote  |  Print  |  Notify Moderator
2 EU2000i's will run your RV including AC. 1 may or may not run your AC. Great little units...
Scott
2005 Dodge 3500 4X2 HO CTD Dually 6 Speed
2005 Springdale 266RELL GL
Reese HP Dual Cam
Prodigy BC
2 Honda EU2000i's
2 Lifeline 31 Series AGM 12V RV Batts
2006 Harley XL1200R
SP 2610 GPS
26" Samsung LCD HD TV
Paul Clancy
BC Canada
Posted: 07/07/08 07:30am Link  |  Quote  |  Print  |  Notify Moderator
You cant go wrong with the hondas. Start with 1 and add a second if you need it. I had the eu1000 just to charge batts and now have the Yamaha 2400is and can run 13,500 ac etc. . Yamaha also is a great unit.
