Bubba Dan
Fort Worth, Tx.
We will be going to South Fork, Colorado from Fort Worth, Tx.
I have been told that there is a pass on hwy. 160 that is very dangerous to pull a TT through.
My TT is a 04 FB25 Puma weight loaded 5200 lbs. my TV is a 06 Dodge 1500 with the towing package and 5.7 hemi.
Will this be safe to go through the pass?
Thank in advance for your help.
Dan
Danny
Fort Worth, Tx.
Newbie
JFG
TN
La Veta pass.... about 9,500ft... it's not that bad... especially downhill side for. Just watch temp gauge.
Fred
Dick_B
Palos Heights, IL USA
A good resource is Mountain Directory West; www.mountaindirectory.com and other sources.
Dick_B
2003 SunnyBrook 27FKS
2003 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
MoRambler
Springfield, Missouri
The only pass you should encounter is La Veta like JFG mentioned, and it is one of the easiest passes in Colorado. You should have no problem. Just past South Fork is Wolf Creek Pass, however, if you're only going as far as South Fork, it won't be an issue. Enjoy the best part of Colorado, in my humble opinion.
Larry & Ann w/Lucy the cocker
'00 Mountain Aire 350 Cummins/Spartan
Toad: '05 Jeep Liberty Ltd.
johnna
Southwest, Utah
The only pass you will be going over is North La Veta Pass. We hauled our 35 ft. 5th wheel over this pass last year. Do not recall any drastic conditions. Nice two lane road with wide shoulders. East to west, long grade up to the summit, shorter grade down. West of South Fork is the Wolf Creek pass. It's a little more challenging, but not dangerous. Hundreds of RVs and 18 wheelers go over both passes each day.
2004 Ford 350 Super Duty 2W Dirve Long Bed PU
2008 327RLT Montana Mountaineer 35 ft. 5th wheel
2005 Alaska and other Trip Logs
BB_TX
McKinney, Texas
Agree with the above. Just returned from South Fork, pulling the 5er both ways over La Veta. Not a problem at all. Just keep a watch on your speed down each side and watch the signs for curves and reduced speeds.
Martyn
Bennett, Colorado, USA
LaVeta pass is very easy - you should be just fine. Good road and good width. I towed up there last year double (with the boat behind the 5er) and was in cruise all the way up. Now, Wolf Creek Pass to the west is a different matter. Great road but needs a lot of attention! Did that OK too - now I don't worry about any of them. Just watch your speed going down and you will be just fine.
2004.5 Dodge Ram 2500 QC CTD 4x4 SLT; 2007 Coachmen Chaparral 267RLS;
Reese 15K Slider;Prodigy;JT Stabilizers;2 Honda EU2000i's;
2006 Glastron MX175;
rv-forums
2005 Dodge Magnum for the DW
GizmosMom
Central Texas
If you are reluctant to drive and pull on mountain passes you might consider this route:
Highway 287 to Amarillo
Amarillo to Clines Corners on IH-40
Clines Corners to Alamosa on Highway 285
Highway 160 west Alamosa to South Fork
However, I agree that the LeVeta pass is not so bad.
Marilyn w/ Joe, 2000 Xplorer Class B van, usually pulling a Ranger bass boat.
Smudge, (in photo) a Shih Tzu/Yorkie Mix and Gizmo is waiting at the Rainbow Bridge
kennethwooster
Perryton Tx USA
I agree with the others. Just take your time, and it will be just fine. It takes awhile to get to the top, but its jsut a good steady pull. I pull a 38 ft. 5th and don't worry about it at all. The downhill side is easy, and not near as steep. Its great country to go to. Have a great time. I'm still hoping to get to Fun Valley at least once this summer.
kenneth wooster- farmer
wife Diana-adult probation officer
365BSQS Quad slide 2007 Quantum
Ford F350 2005 model, 4X4 FX, King Ranch
18K SuperGlide Hitch
cruiserjs
Aurora, CO, USA/ Mesa AZ/ openroad
Neither of the passes (La Veta or Wolf Creek) on 160 in CO should be called "very dangerous' for RVs! Who ever said that to you probably should not be driving an RV! La veta is very easy to pull in either direction. Wolf Creek IS a long pull and most Rvs will be going pretty slow, up and down in both directions but has very adequate passing lanes for those wanting/ able to pass you. But not dangerous! Worthy of some caution - OK! I get pretty tired of t hose folks who scare others - or try to.
Colorado Cruiser
Cruiser CF29CK 5th wheel; 2001 Silverado 2500HD shortbed
wonderful lifetime travelling companion/spouse
