jk+6
nc
We have a 2007 crossroads zinger 29DB that came with Milestar tires (ST 225 75D15). We just purchased it Jan 08, and the tires are bald. We are currently traveling with the trailer, and we need to replace them before we can get back on the road. Does anyone have any recommendations as to which tires to purchase, and which tires hold up better. We have only driven it 2,000 miles (maximum estimate).
Also, we are using the trailer currently so we would like to replace the tires without moving the trailer. Does anyone have any recommendations on how to do that? We have two floor jacks that we could use to support both sides so we can remove all four tires at the same time and then replace. Does anyone have any advice or experience with doing that?
Thank you! Any help would be VERY appreciated!
wrenchbender
Phx
Maxis, Goodyear, Try to go with a 10ply load range D.
coolbreeze01
Redding, Ca
Your axles must be out of alignment. My Milestar tires have over 2,000 miles on them and they still look new. Good luck.
2008 Dodge 3500 CTD LB SRW 4X4 6-Speed Auto
P3 Blue Ox Sway Pro
2007 Komfort 212
Scott&JodyB
Gresham Oregon
The Milestars I had on my Keystone were recalled and replaced for free. You may want to check with your dealer. I had a choice of three replacement tires.
tvman44
Southwest Louisiana
If you wore out the tires in 2,000 miles you have a serious problem. Need to get to a dealer or trailer shop that can check your alignment.
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
amxpress
Clayton, NC
Quote: If you wore out the tires in 2,000 miles you have a serious problem. Need to get to a dealer or trailer shop that can check your alignment
I agree. No way should you have worn out a set of tires in 2000 miles!
Don't spend the money on new ones until you correct the problem or they'll wear out, too.
Maxxis tires offer a radial tire in that size. They seem to be rated highly on the forum. I had them on my TT and liked them.
But first, have a QUALIFIED shop check your rig for bent axles or an out of alignment condition.
2007 Dodge RAM 2500 Quad Cab w/6.7 Cummins
2008 Palamino Sabre 31RKTS
Reese 15K Pro Series manual slide
Prodigy
Firestone Air Bags
Travel in peace...leave the M-I-L at home.
VTR Pat
Chandler, AZ
We replaced our Goodyear Marathons at the 5 year mark following a tread seperation out in the middle of nowhere. Trusted tireshop near home said stay with the Goodyears.
Maxxi's seem to have good rep here on the forum.
BUT something way out of wack if there're bald at 2K miles, or the TT came with used tires, really used!
'O3 Dodge 2500 Quad Cab, 4 x 2, Auto, 2 Tone Graphite over Silver, HO Cummins Turbo Diesel, 3.73 anti-spin.
'02 Prowler 25-J Northwest Edition, Prodigy controller, Equal-izer.
AJS211
new york
Hi
We have a similar problem to yours. We have only traveled about 1000 miles and one of out tires is completed bald and the others are cupping and show signs of wear. We think the problem may be the link the connects to two leaf springs together because when my husband makes shap turns w/ the trailer we hear a snapping sound from them. He thinks they are binding and not straightening out casuing the tires to ride either toed in or toed out. What do you think? Do you hear any similar noises???
Anthony, Janice, Little Anthony & Butch the Dog
05 Ford F350 Lariat Supercrew PSD
08 Sunnybrook Sunset Creek 269BH
CatNPaul
Richmond, KY
We have an '07 Springdale that had Milestar tires that had dry rot after less than 6 months and probably less than 1,000 miles. We asked our dealership and found out the tires were part of a huge recall. I suggest you find out if your are included in that recall, and if you have to replace them right away, find out what you need to do in order to recoup that money.
Good luck!!
Turbo Diesel Dude
Green Mountain, NC
Maxxis ST225 75R 15 load range "E" 10 ply. Load range "D" is only 8 ply.
charles weidman
