RV.Net Open Roads Forum: Class A Motorhomes: Need help with Splendide 2000 washer
 > Need help with Splendide 2000 washer
CaBoy
Junction City, OR USA
Posted: 07/06/08 11:08pm Link  |  Quote  |  Print  |  Notify Moderator
Please let us know what the final fix is, good luck.
The older I get, the better I used to be.
1997 Prevost by Country Coach
470 HP Series 60 Detroit / 6 SP. Allison
2005 Jeep Grand Cherokee Toad
Same Co-Pilot for 43 years
2 Boston Terrier girls, Scooter & Mia
ChaosAgent
Fairbanks, AK
Posted: 07/07/08 01:17am Link  |  Quote  |  Print  |  Notify Moderator
Tedtoo wrote:
When it stopped working, the dial was still on the wash cycle--. I can turn the knob to Spin, but nothing happens. I am thinking the timer 'motor' is gone.
Judie
Just a thought. If the problem were the 'timer motor' then manually advancing the knob would activate the different functions as you turned it.
So I doubt it's the motor itself.
It does sound like it has lost power somehow.
'99 American Eagle 40NS
'04 Dodge Dakota 4x4 Crew Cab Toad
DH
DW
Mister & Emma - Designated Coach Cats
How did we miss Utah?
Fulltimingman
Livingston, TX, USA
Posted: 07/07/08 06:38am Link  |  Quote  |  Print  |  Notify Moderator
If it is possible to slide the unit out of the cabinet or to get to the top and rear of the unit, there are screws near the top on the rear of the washer that hold the top in place. Remove these screws and slide the top rearward a little and carefully remove the top. See if the ground plane which is mounted on the underside of the top of the washer has come loose and is grounding out some of the electric connections. If so, drill at least four small holes in the large metal ground plane and use very short sheet metal screws to secure it to the plastic top of the washer. If the ground plane is still in place, check the electrical connections going to the timer to see if they are secure.
Michael Day
Newell Coach
PT Cruiser Turbo
Patrick the Irish Wolfhound
Native Texans
Tedtoo
Livingston, Texas
Posted: 07/07/08 06:42am Link  |  Quote  |  Print  |  Notify Moderator
Thank you, thank you, thank you! After I turned it off for 10 minutes and then moved it past the reset, it started again! Now I'll be able to get the wet clothes out! I love this forum!
Judie
sasteel
Springville, TN
Posted: 07/07/08 10:58am Link  |  Quote  |  Print  |  Notify Moderator
Are you sure you actually have power going into the washer? Check at the point where it goes into the washer.
Scott Steel
Springville, TN
