RV.Net Open Roads Forum: Travel Trailers: Adding BAL stabilizer jack - suggestions?
 > Adding BAL stabilizer jack - suggestions?
djtkach
Manitoba, Canada
Posted: 07/06/08 05:22pm Link  |  Quote  |  Print  |  Notify Moderator
I bought two new BAL jacks to add to our TT to take some of the bounce out of it. Fortunately I followed the directions and test-fitted the jacks with c-clamps before drilling the frame and mounting, as it revealed the reason for my question below.
Our TT has a moulding which runs about 5" below the frame along most of the side. If I mount the BAL to the frame as is, when I fold the jack up it will hit the moulding and not fold completely. To solve this, I need to mount the BAL about 3" below the frame, which will leave sufficient clearance. Note that even with this 3" drop there is still plenty of ground clearance, so jack dragging is not a concern here.
To give me the clearance I need I was thinking of mounting a 3" thick block of treated lumber on the jack, then drilling through the block and the frame and bolting all this to the TT. Any thoughts on this or other suggestions?
DavidG
near Seattle, Washington, USA
Posted: 07/06/08 05:44pm Link  |  Quote  |  Print  |  Notify Moderator
I would not use wood as a spacer for this purpose. I would have a welding shop get some square tubular steel and weld it to the jack and then the frame. Take a look at most Fleetwood trailers to see how they do it.
David and Laura G
Click here for RV Towing Tips and more
2003 Suburban K2500LT 4WD, 8.1L, 3.73, Autoride 14-16 mpg hwy, 10-12 city, 8 towing
2008 Adirondack 31RL
Prodigy brake controller, Surge Guard
Bucky Badger
Madison, WI
Posted: 07/06/08 07:57pm Link  |  Quote  |  Print  |  Notify Moderator
I agree with David, about welding a block. BTW how are the other jacks mounted on the TT?
2007 Nissan Titan, 5.6L Big tow, Equli-z-er Hitch
2007 Forest River Salem 27RB LE
Member Titantalk.com
Nights camping 08 (35)
Rallies/Gatherings
IL
WI
djtkach
Manitoba, Canada
Posted: 07/07/08 07:52am Link  |  Quote  |  Print  |  Notify Moderator
The other jacks are bolted directly to the frame, and clearance is not an issue as the moulding does not run all the way to the front and back of the TT.
