RV.Net Open Roads Forum: refridgerator without putting a hole in the roof?
 > refridgerator without putting a hole in the roof?
gslim
Boise, Idaho
Posted: 07/06/08 06:17pm Link  |  Quote  |  Print  |  Notify Moderator
Is there a propane fridge you can get that doesn't require a hole in the roof? I am retrofitting a v-nose car/hauler and would like to not put a hole in the roof. A hole in the side isn't that bad but a hole in the roof doesnt really make me feel happy.
thanks for your time.
In the proccess of converting a interstate V-Sport trailer into a toy hauler because they dont make drive in drive out toy haulers that can haul a car. Radio (check) Stove (check) , HEAT (check), Now a Bed (zzzzzz)
skipnchar
Topeka Kansas USA
Posted: 07/06/08 06:20pm Link  |  Quote  |  Print  |  Notify Moderator
Pop up trailers that have very small refrigerators vent the burner out the side but that would be a tiny refrigerator. I'm not sure I've ever seen any of the larger models without a roof vent. If you don't dry camp consider putting a 120 volt AC fridge inside so you don't have a burner to vent. It'd end that old debate about "gas on or off"
tandkj
Full timer
Posted: 07/06/08 06:22pm Link  |  Quote  |  Print  |  Notify Moderator
Look at a PUP and you can see that they go out the side because of the roof going up and down. You could adapt yours to this configuration but the fridge is small and you may want a larger firdge.
08 Camelot
07 Ranger Toad
One lost Golden Retriever
USAFBILL
Alabama
Posted: 07/06/08 06:23pm Link  |  Quote  |  Print  |  Notify Moderator
My friends Big Sky does not have a vent out the roof. It has 2 side vents one right above the normal side vent.
C Schomer
Buckeye, Az.
Posted: 07/06/08 06:26pm Link  |  Quote  |  Print  |  Notify Moderator
All the fridges in slides vent out the side. I had one side vent fridge and that will be the last one. It wouldn't keep anything cool and the freezer was totally worthless. Craig
tom_kat
way upstate new york/lake george area
you could probably go out the side just below the roof with duct work and a grill over the hole,you would probably also need a fan running during warmer weather to get the air flowing for ventalation which you need for better cooling.maybe a solar panel hooked to a fan direct to run when the sun comes up for air flow.
1985 Class A Holiday Rambler Imperial 33 +1979 Class C Holiday Rambler Statesman 1000 = 24 ft
klutchdust
Orange, California
Posted: 07/06/08 06:27pm Link  |  Quote  |  Print  |  Notify Moderator
I explored different options as i didn't want to do that either and I found the smaller capacity gas fridges you can get away with two side holes, one being an intake and one being an exhaust and a 12 volt fan will add to the efficiency. Start looking into the fridge you would like and research their installation requirements.
I installed 12ft. living quarters in a cargo van.
Big Katuna
Deland, FL
Posted: 07/06/08 06:51pm Link  |  Quote  |  Print  |  Notify Moderator
My DP has a double door fridge in a kitchen slide with wall vents and it works great. It does have a thermostatically controlled fan.
My Kharma ran over my Dogma.
JUrban
Delaware
Posted: 07/06/08 06:55pm Link  |  Quote  |  Print  |  Notify Moderator
We had a big Norcold 4 door fridge/freezer in our last 2005 Diesel Bounder that had 2 external side access panels. Worked great, so it can be done. You need a few additional heat shields, but it's very common. Look at any rig with the fridge in a slide.
John
2008 Tiffin Allegro Bus 40' QSP
2006 Chevrolet Colorado Toad
BlueOx Aventa LX Tow Bar
SMI Air Force One toad brake
Copilot Live Laptop 10 GPS
Wherever I happen to park
Posted: 07/06/08 07:48pm Link  |  Quote  |  Print  |  Notify Moderator
Yes. they vent back out of the side
Also, Norcold had a couple of models that don't use propane, they are 120/12 volt. I'm not sure if you can get one in the size you want though. (They draw less than 40 watts (4 amps on battery) so they are real nice.. I have a competitor's portale product in my kitchen)
* This post was edited 07/06/08 07:57pm by wa8yxm *
