The Harpers
Carmel, California, USA
I use Caftsman 1.5 horsepower, 2 gallon tank. Would not travel without it. I bought it at Orchard Supply. $99.00 with a no tax day.
Tom and Sydney Harper - Monterey California
2004 HitchHiker II LS 32.5 UKTG
2003 Chevy Durmax Diesel
Travel companion our faithful rottweiler, Addie[b][/b][b]
Note: Due to invalid formatting, all formatting has been ignored.
Dennis Bham
Alabama
For portable ... MV-50 for 12v ... Keep in tow vehicle at all times - light weight - works great - plenty of capacity for my TV and trailer 10 ply 80 PSI tires ...
MV-50 at Amazon - Free ship
For the house I use a Makita "Hot Dog":
Makita "Hot Dog" at Amazon - free ship
Dennis
edited 07/07/08 05:55am by Dennis Bham *
'08 Chevy 2500HD Duramax 4x4, Crew Cab, Std Bed e/w 18K Superglide
'08 Cougar 292RKS, e/w 16" Sendel wheels & BFG Commercial TA tires
PressurePro TPMS
up2nogood
Utah
About how long does it take to inflate a average truck tire up from say 40 lbs to 80 lbs (285/75/16 ) I have used the old 12V and they are pretty slow. Thanks
HUTCH45
NORCAL
SoCalDesertRider wrote: HUTCH45 wrote: I use this same exact model...WAAAAAY too efficient to think of using a 12V unit, (IMHO). No electricity...? I run it off one of my Honda EU2000s.
Have needed it in a pinch at rest stops...I feel secure knowing it's in the back.
My $.02 is all.....enjoy the journey..
By the way, HUTCH, did you race BMX back in the early days?
Nope, but I did flattrack a 40" Triumph back in the late 60s/early 70s, (T-120 w/'Trackmaster' frame). District 36 Sportsman Expert...73R.
Those were the good old days for sure
"HUTCH"
'07 SILVERADO 3500HD 'CLASSIC' DRW - CC - 4 X 4
'07 NEW HORIZONS 35' 5th.Wheel 'MotoMover'
'06 HONDA 106hp.VTX1800 w/'HANNIGAN' Sidecar
"PRIMO" The Boxer
Dennis Bham
Alabama
I've never done exactly that ... but this is a hi-flow pump (2.54 CFM) ... It is not your typical little 12v pump ... I'd say it could do that in 1.5 to 2 minutes. I have used it go from 65 to 80 PSI in a 16" tire and it took about 30 seconds ... It pulls more current than most cigarette lighter plugs can supply, so it comes with clamps that you apply directly to your 12v battery.
cspera
st petersburg fl 33703
Harbor Freight x 2
Periodically on sale for $50 Normally $70 but on sale almost every 2 or 3 weeks
12v clamps directly to battery
easily tops off 80# and 105# tires.
cspera@tampabay.rr.com
jpt51
Central Texas
I have a Porter Cable pancake but wish I had the Husky. It's okay if I want to add 5 lbs but takes forever if adding 20 lbs.
jhufft
CALIFORNIA
I would use a heavy duty air compressor like for off road ect.
I use the extreme outback jr compressor I have had it for about 3 yrs now and I love it I can run it continuous if I want and it will not shut off like the other that plug into the cigarette lighters also the off road compressors come with heavy duty fittings and can be easily adapted to run air compressor tools {impact wrench ect.}
hope this helps
happy camping and good luck
smkettner
The only trouble I have found with the 12 volt is that with no tank the moisture does not collect and is pushed into the tire. With a tank the moisture collects to be drained out later. Probably a minor issue but the nitrogen people would have a cow.
