RV.Net Open Roads Forum: Torque Setting Of Lugs on a Class A DP??
 > Torque Setting Of Lugs on a Class A DP??
tcr1016
Leander, TX
Posted: 07/06/08 09:42pm Link  |  Quote  |  Print  |  Notify Moderator
Anyone know the torque setting of the wheel lugs on the duals and front?
1995 Safari Sahara 33' (5.9 230HP Cummins Diesel) Diesel Pusher
Daily Driver even to the store, Home Depot, restaurants, etc.
1 Dog (Great Dane/Greyhound Mix) goes everywhere with us.
My License Plate Frame Reads:
MY BIG
TEXAS SIZE SUV
Golden_HVAC
Fulltime, CA, USA
Posted: 07/06/08 09:49pm Link  |  Quote  |  Print  |  Notify Moderator
Call Safari Monday - Friday and they will tell you.
It will help if you have your VIN number so they can look up your exact coach.
I know that it will be over 130 foot pound of torque that my F-350 uses. It all depends on the size of the lug nuts and studs. My F-350 and current F-53 (equal to the F-550) use 9/16" studs rated at 130 foot pounds.
If you are on the roadside and need to tighten them tonight, I would suggest using 150 foot pounds and then retorque them when you get the correct measurement.
Fred.
Money can't buy happiness but somehow it's more comfortable to cry in a Porsche or Country Coach!
If there's a WILL, I want to be in it!
Improve a life KangenPowerTeam.com Akaline Water.
I havn't been everywhere, but it's on my list.
Escapees.com
Gale Hawkins
Murray, KY
Posted: 07/06/08 10:07pm Link  |  Quote  |  Print  |  Notify Moderator
The P30 with 19.5 wheels is 175 foot pounds for what it is worth. I agree with Fred's 150 pound suggestion will keep the wheels from falling off any time soon.
escaper1
Centerville,Ohio,USA
Posted: 07/06/08 10:51pm Link  |  Quote  |  Print  |  Notify Moderator
Mine torque to 450 ft pounds on a diesel pusher which I think is pretty standard.
othertonka
Stockton, CA
Posted: 07/06/08 10:52pm Link  |  Quote  |  Print  |  Notify Moderator
With your 1996 Safari, I would think it had the regular "cone" shape lug nuts and probably 150 ft lbs. I would suggest that you call Safari with yout VIN number and get the right figure directly from them. In later model years they started using what they call "Hub Piloted" Lugs, lugs wirh a flat washer on them, and these systems require 450 to 475 Ft Lbs. Here is a link to Safari which shows these lug nuts and how to tighten them. Good reading to understand the difference.Hub Piloted lugs
Another article about Hub Piloted lugs can be good reading for those who have these type of Lug Nuts found on many models built in the 2000's. Hub Piloted
* This post was edited 07/06/08 10:58pm by othertonka *
Othertonka
2004 Southwind 32VS
2002 CRV Toad
U. S. Gear Unified brake system
Retired Fire Captain, SFD
djevans
Tennessee
Posted: 07/07/08 05:07am Link  |  Quote  |  Print  |  Notify Moderator
You should call Safari as others have suggested. Ours have to be torqued to 450 ft lbs. It's marked right on the nut. 150 or 175 would only invite "issues" if yours happen to require 450.
Don . . . near 36.171N 086.784W, TN near here
WA4ZFN
2003 Fleetwood Revolution 40C - Saturn VUE
350hp Cummins ISC
- - - P i c t u r e s - - -
I'm confused, WAIT! Maybe I'm not!
Works2RV
Summerville, SC, USA
Posted: 07/07/08 05:41am Link  |  Quote  |  Print  |  Notify Moderator
Same for ours - according to the chassis manual.
1987 36' Beaver Marquis High Tech Wide body
3208T CAT, MT643 Allison in a Gillig MHA
Koni's & Toyo all around
FMCA, Good Sam
Jetta TDI
Marsha & Buck
Sully2
Cincinnati
Posted: 07/07/08 07:14am Link  |  Quote  |  Print  |  Notify Moderator
Depends on the wheels! BOTH of my P30 were 115-135 lbs of torque
2000 Country Coach Allure; Cummins ISC 330 HP; 71/2 - 8 MPG regardless
2002 Jeep Liberty
tcr1016
Leander, TX
Posted: 07/07/08 05:11pm Link  |  Quote  |  Print  |  Notify Moderator
Monaco said 450LBS torque. A tire shop that only deals with semi truck tires said use a 4 foot cheater bar. Push on it till you can't anymore. That is the best way since no one has a high pound torque wrench. Also it makes it easier to remove with the cheater bar.
Thanks for all your help.
othertonka
Stockton, CA
Posted: 07/07/08 05:43pm Link  |  Quote  |  Print  |  Notify Moderator
They make a torque wrench that goes up to 600 ft lbs but they are quite expensive. I am fortunate to work for a company that has one and I can borrow it when I need it, but if I need it on the road, I call road service. I do carry a socket, flex handle and a 4 foot cheater bar for use in an emergency. 115 lbs of force on a 4 foot bar should give you 460 ft lbs.
Here is a link to a torque wrench.Torque Wrench
Also read the link below about putting a couple drops of oil between the washer and nut on the "Hub Piloted" lug nuts before you torque them.
Hub Piloted Lugs
