RV.Net Open Roads Forum: Class A Motorhomes: Black Tank is Plugged...Suggestions Please
 > Black Tank is Plugged...Suggestions Please
decan9
Oceanside, CA
Posted: 07/07/08 10:37am Link  |  Quote  |  Print  |  Notify Moderator
Had this problem on TT once. hooked waterhose to the hose port on the endcap, opened the valve and turned on the waterhose...backflushed it out, then close the valve and should be able to make the dump. you're going to have a little residual when you start to reconnect the sewer hose, maybe couple of pints!!!
Bonnie and me and Casey makes three!
Staying warm in Southern California
FMCA #402157
W9NCR
Tinstar
McKinney, TX
Posted: 07/07/08 10:38am Link  |  Quote  |  Print  |  Notify Moderator
Diggin has a good idea. A small snake through a short water hose that is screwed to the outlet on the cap. You can hold it up high like Bingoldsby suggested and run the snake in and out until you are able to get the "water" flowing. You can drain the hose into a bucket after you close the knife valve. NO MESS!!!
Never pass up a chance to go somewhere
ArchHoagland
Clovis, CA, USA
Posted: 07/07/08 10:43am Link  |  Quote  |  Print  |  Notify Moderator
Let us know whatever you find.
My bet is the tank wasn't drained and the stuff in it has solidified.
May I suggest some plain old Dawn dishsoap and some fabric softener. If you can drive around for a few miles and get that stuff stirred up it might help.
You can also stick a garden hose with a high pressure nozzle down thru the toilet and blast away.
I fill my tanks full when I store my rig and empty a day or so before we leave. I've got full hookups at my house. Keeps the sensors clean...somewhat...and no odors build up.
2004 Monaco
La Palma 36DBD
Two Slides
2 Potties
Workhorse 22 chassis
8.1 gas engine & Allison transmission
6.9 MPG based on a 6,000 mile trip around the U.S.
US Gear Toad Brakes
dbbls
Missouri
Posted: 07/07/08 02:03pm Link  |  Quote  |  Print  |  Notify Moderator
Don't you just love these posters that say it can be done with no mess, or very little mess. I don't think there is a non messy way of unplugging it. I would add lots of water and drive around on rough roads.
1999 F250 Superduty, V10 with Banks Power Pack
2004 Colorado 29RL 5th wheel with 3600 watt Onan
Sully2
Cincinnati
Posted: 07/07/08 02:28pm Link  |  Quote  |  Print  |  Notify Moderator
How do you know its not the knife valve itself thats damaged and not a tank 1/2 full of solids??
When was the last time you lubricated ( if EVER) the knife valve itself?
2000 Country Coach Allure; Cummins ISC 330 HP; 71/2 - 8 MPG regardless
2002 Jeep Liberty
Wherever I happen to park
Posted: 07/07/08 04:14pm Link  |  Quote  |  Print  |  Notify Moderator
Ok, Well, odds are if you are trusting the sensors your tank is nearly as dry as the Saraha... (Well one of 'em anyway)
The sensors are simply screws or nails that goes through the side
Since contaminated water conducts electricity if they are "under dirty water" they are shorted to ground. And the "Meter" reads that.
Now, if there is some "Slime" on the side wall, it may false the reading
If a bit of TP gets hung up on the "probe" it may falst the reading
And that is what happens.. The tank is fully empty, the sensor can not figure it out.
I have been known to pressure wash the sensor wall
427435
Rochester, Mn
Posted: 07/07/08 05:04pm Link  |  Quote  |  Print  |  Notify Moderator
With your tank 1/2 to 3/4 full, add a box of dishwasher soap and let it sit for a day or two. Then find a rough, rolling road and take it for a drive.
If that doesn't work, then on to the messy methods.
Also, as Sully mentioned, be sure your gate valve is actually opening.
Mark
2000 Itasca Suncruiser 35U on a Ford chassis
2003 Ford Explorer toad with US Gear brakes,
ReadyBrute tow bar, and Demco base plate.
fireman148
Collierville
Posted: 07/08/08 09:06am Link  |  Quote  |  Print  |  Notify Moderator
I think I'd get a sewer rooter and see if I could get lucky enough to hit the drain hole from the toilet side rather than the drain end and get the poo on me....
Easy Rooter
bustersbud
Based in Southern Ontario
Posted: 07/08/08 09:46am Link  |  Quote  |  Print  |  Notify Moderator
Update on my situation. After a drive last night got a couple of cups of yicky brown liquid, about the same this morning. I counted last night, here are three 90 degree elbows between the tank and the knife valve so nothing is easy.
02 38' DutchStar, 02 Explorer Sport Trac 4x4, Remco Disconnect.
Ever Increasing Amounts of Useless Information
RV Questions
hohenwald48
Hohenwald, TN
Posted: 07/08/08 09:51am Link  |  Quote  |  Print  |  Notify Moderator
Backflush with something similar to Flush King woould be my first try. Without a doubt it would be the cleanest and easiest solution. If that doesn't work then it's on to the really dirty work.
Chris
2001 Monaco Knight
2004 Dutchmen Dorado
1999 Jeep Wrangler
100% Solar Powered Home
When seconds count, the police are only minutes away.
