Jchavez
Albuquerque
This is what happens when your pin assembly that hold the landing gear up and down falls off while your going down the
Jimmy and Karen 1st wife,Kasey 9 2nd wife, Vanessa 3 3rd wife
2005 Dodge 2500 w/cummins 4x4 SB pulling 2007 Jayflight 27.5 BHS 5th wheel
Jchavez
Albuquerque
A couple of more pictures
The little pin assembly just fell off.Do you guys think that Jayco will warranty it?
Sorry guys this picture shows the assembly that fell off
Polishnurse
Schodack, NY
I bet it made some noise alright, but kind of like a tree falling the woods, does any one hear it.
goin2themountains
Aztec, NM
Bet the guy following you made some noise. Looks like the bolts holding the spring loaded pin vibrated loose. I guess you didn't notice any slack in them when when lifting the landing gear lower assembly? (btw, made up that term. dunno what you call the bottom of the landing gear)
Puller: '04 HD2500 4x4 SB,EC Duramax/Allison. Airaid intake, 4in. exhaust turbo back, ORU leveler.
Pullee: '02 Keystone Cougar 276EFS Reese 16k w/ slider.
(map is for current 5er only)
benb21601
Resident Expert
i dont see what that wouldnt be warranty-only a year old and you should have two years from jayco, plus whatever other components have. good luck with getting it off the truck.
07.5 GMC Sierra 2500HD SLT-Crew Cab Short Box, LMM, SuperGlide, Prodigy
07.5 Jayco Eagle 345BHS-Trip Slide 5er, TrailAir Pinbox, Shocks, Aluminum Tripod, RotoChocks
04 Honda EM5000S Generator
Me,DW,DS,DD,DGSD
Our Picture Page
Jchavez
Albuquerque
Polishnurse wrote: I bet it made some noise alright, but kind of like a tree falling the woods, does any one hear it.
No noise at all was pulling into a gas station,It dropped about 5 feet in front of a speed bump.The only noise it made was when the leg with the foot hit the asphalt kind of like tink noise.Thats what me stop.
Good thing it didnt happen on the freeway or that leg would have hit someone elses car or they would have hit it.
dbbls
Missouri
I hate it when that happens!
1999 F250 Superduty, V10 with Banks Power Pack
2004 Colorado 29RL 5th wheel with 3600 watt Onan
RogerMo
Missouri
My 2007 JayFlight came with bolt on pin set. The pin went through only one set of holes on one side of the leg, not all the way through the leg. I removed them and put the old conventional pin with the snap ring attached. Not because what happened to you, but because some were dropping while setting at the camp site or in storage.
K.A.
05 2500HD Silverado 6.0L 4.10 rear end
2007 Jayco JayFlight 28.5 with Equa Flex
Rmcgrath53
Howell
Those will work with only one leg. Looks like a flamingo.
2009 sundance 2997bhs
f350 4x4 7.3 diesel
prodigy 3p curt 20k hitch
trail air suspension trail air pinbox
2 e2000 honda w parralel kit
KSadler1
Albuquerque, NM
Jim, I can't see the picture real clear. Was this a full "push through pin" that came out or was it a "spring loaded type"? The problem you're going to have with Jayco is they will try and say you didnt make sure it was secure. If this was a "spring loaded type" that you installed after purchase then they probably won't cover it.....
Ken
