Fraser in YYZ
East York, Canada
We are about to take the plunge on a new TV and want some of your expert opinions to help us make up our minds. We will be towing a 08 Jayco 213 Exp which maxes out at 5500 lbs.
Option #1
05 Dodge Durango Ltd 4X4, 5.7 litre Hemi/Magnum able to tow 8650 lbs.
Option #2
05 Dodge 1/2 ton Ram 1500 Slt Quad cab 4X4, 5.7 litre Hemi/Magnum able to tow 8600 lbs.
I'm liking the Ram while the DW is leaning toward the Durango. Tough choice!! Your input will be gratefully accepted!!
Thanks in advance.....
Fraser
DW
2 sons 13+16
2008 Jayco 213 Exp
2005 Dodge Durango 5.7 Hemi Magnum.
Prodigy brake controller
Husky WD hitch with friction anti-sway
A bad day of camping is better than ANY day stuck in the city!!
mikehart92
Oklahoma
I'd take the truck's longer wheel base over the suv for towing any day.
Mike
2005 Chevy 2500HD.............6.6 D/A, 4x4, Crew Cab
eaglesnest1
new york
I personally like the truck over the Durango. The bed of the truck holds a ton of stuff which you will no doub tfill to capacity the longer you have your camper. Good luck.
Lifes Too Short"
newsomer
Northeastern Illinois
Although the Durango's wheelbase should be marginally adequate I would still rather have the Ram for future trailer considerations and overall utility value.
2007 Chevy Silverado extended cab, 5.3L, Z85 - 2008 Starcraft Travel Star 27RBH - Equal-i-zer
To Infinity, and Beyond!
skipnchar
Topeka Kansas USA
With that size trailer either vehicle should tow it easily. Get the one you like best.
10tca01
Columbia Missouri
The Ram hands down, you can haul more stuff, have a longer wheel base, and they just look cooler!
dkomeshak
Southern Illinois
What's the GVWR of each vehicle? Our 2004 Durango had a GVWR of 6600 lbs. When we added the hitch weight and all of the other stuff, we were there or above.
Edited to change GCWR to GVWR.
2005 Ford F250 SD CC LB Lariat 6.0 PSD
2008 Airstream 27' FB International Signature Series CCD
fordsooperdootydieselsmoker
OrangeCountyCalifornia
Nuttin like a good ole 'merican pickumup truck!
z_i_m
alabama
what ever is cheaper on 4.20 a gallon...........
edited 07/08/08 04:53am by z_i_m *
GHarper
New Hampshire
All I will say is KEEP THE WIFE HAPPY and you will be happier!
1994 Suburban 3/4 ton +
2008 Crossroads Zinger ZT29DB
