Clive24332150
Victoria, British Columbia
Hi Guys
We are just starting to look around for a good used Class 'A'. One of the units is a 2003, 38ft Dutch Star with the Cummins 300hp engine. I was told that this engine is not strong enough for this M/Home. Especially for full time usage. Is this true? and should I look for a bigger engine or is this Bull?
Cheers
2006 Zeppelin. Z-241
2003 GMC Envoy. Xl. SLT. 6 cyl, 275HP. 4X4.
Equal-i-zer 4 Point Sway Control
jwmII
out west
Is it the Cummins B series engine? If so it is an excellent engine for lighter vehicles and applications such as the Dodge Pickup.
Compared to other Cummins engines that are available the B is a little light on torque.
There are those that will swear by this engine for their large coach. Do your homework and make your decision.
jwmII
v8q
Oviedo, FL
That hp in an 03 would have to be a B series. An ISC would be a 330 or 350. I would say thats a bit small. If it were an 8.3 it would be ok...
Dave Head
Oviedo FL
95 Foretravel U320C SE
M11, HD4060
ROwen
British Columbia, Canada
There are many factors involved in this question, but I like the general rule of keeping the load per HP in the 90-100 lbs range. Closer to 90 is better. The load should be the gross load including tow vehicle.
In your case, the GCWR would have to be between 27,000 and 30,000 lbs. to make this work.
I know that there are many, many MH's on the road happily outside of these parameters - I just like to have the power there when it's needed.
From my experience, not full-timing, but using the MH for months at a time, you will load it up to max when full-timing.
2005 Country Coach Inspire DaVinci 40'
2008 Honda CRV Dinghy
flhtci-rider
Montreal, Canada
At least make sure you have a 6 speed and not a 5 speed tranni. Had a HR Neptune with a 5 speed and found it reved on the high side. It was a great engine but for myself I felt it was underpowered. If you can find a unit with an ISL (400) you will be much happier
2006 Scepter
2008 24' Haulmark EDGE
2003 Grand Vitara
My best friend DW
1 fur ball Max (AKA - PITA)
And enough solar power so I never have to start the Genni
Deen
Vancouver, WA
Should be the ISC, in 2000 we could have gotten the ISC 325/Spartan as an option over the Freightliner 3126 300/860. In 2002 the Spartan had the 350/1050.
I don't thenk they used the ISB anywhere in that time frame in the DSDP. In some of the cheaper units they did use the ISB, just not in the Dutch Star. I don't think they used the 5 speed either, even our 2000 with CAT 300 had the 6 speed trans. Again, in some of the cheaper models they did go with the smaller trans as I remember.
Deen - Vancouver, WA
'02 Dutch Star 4090 (41+', triple slide)
435/1200 ISC Cummins/Banks PowerPak
'08 Honda Civic/dolly
'05 Honda Odyssey/dolly
NRA Benefactor Life Member
FMCA f47302s, Life Member: Good Sam,
Newmar DP Owners Group
51st yr of RV'ing
dadkids
Virginia
I have a 5.9 ISB engine and am pretty happy. I tow a open trailer with 5 atv's or a escalade on a car hauler and have no problems with power. It does slow down to maybe 35 on steep grades like Sandstone Mountain in WV but other than that I am happy. I have the 5 speed tranny and get around 8.5 mpg running 65 mph average.
Just my .02 cents from personal experience.
2007 Mandalay Valencia 38D bunk bed model
former 06 Raptor 3612 ds
06 Kawie kfx 700
06 Honda Trx 250
08 Polaris RZR
05 Honda 250 Recon
06 Honda Trx 90
2008 Ford F 250 4x4 cc sb king ranch,
Economical Handyman
S. California
Torque pounds for a 300 is 660# not bad for flat landers.
My 370 is 1200 torque pounds and I have been where I would of liked more. Never hear to many complain about to much HP/torque !
DeWayne & Judy
04 3810 Dutch Star
ISL 370
Frank's autoformer
01 Sahara Jeep-toad
F 374382
It is hard to kiss the lips at night, that has chewed your butt all day long!
Norm Payne
Livingston, TX
Clive24332150 wrote: One of the units is a 2003, 38ft Dutch Star with the Cummins 300hp engine.
The 2003 Dutch Star did not come with a 300 horsepower engine. If it is a Cummins ISC it will be either 330 or 350 hp with either 950 or 1050 ft lbs torque and if its a CAT it will have 330 hp.
Look at that Dutch Star again and there will be a sticker on the wall behind the drivers seat. It gives information on the chassis, engine, transmission, tires, axles, etc.
Norm
2005 Dutch Star 4015, Cummins ISL 370 hp
2007 Honda CR-V
See Ya Down The Road
http://www.seeya-downtheroad.com
SteveRankin
Sequim, WA
I've got to ask what fulltiming has to do with horsepower?
Steve & C. J.
"Gracie" the Rough Collie & "Bo'sun" the Bichon Frise
2009 Arctic Fox 29V
2005 Chevy 2500HD Duramax 4X4 Crewcab
Hensley Hitch
TruControl Brake Controller
Our Beaver Technical page
Wildlife rescue at the Northwest Raptor Center
