RV.Net Open Roads Forum: Using Slide-out, Does engine or genny need to be on??
 > Using Slide-out, Does engine or genny need to be on??
Hurricaner
Hurricane Utah
Posted: 07/08/08 06:09am Link  |  Quote  |  Print  |  Notify Moderator
My slide will not operate with the engine running, it is a safty feature to keep someone from operating the slide while going down the road. A slide motor draws no where near what a starter motor draws and you don't start your generator to start the motor do you! Oh wait you can't start your generator because you have to have your engine running or your gen starter will burn up. Man, this is getting confusing. How do those trailer guys do it that don't have either?
Sam
Sam & Kari
Hurricane, Utah
2004 34' Damon Challenger 315
Joy
Henderson KY 42420
Posted: 07/08/08 06:27am Link  |  Quote  |  Print  |  Notify Moderator
Our slides WILL NOT operate when the engine is running. Period. They operate on battery power only. They will operate when plugged in to shore power but are still battery powered.
See ya' down the road!
Don-SCPO USN Ret.Corpsman
Joy-Ret.Off.Mgr.
Katie-Mini Aussie
Sam-Calico Fat Cat
Maggie-Chihuahua
2003 38'Phaeton DP
2006 Saturn Vue
LIFE ISN'T ABOUT HOW TO SURVIVE THE STORM BUT HOW TO DANCE IN THE RAIN.
Dave H M
IL
Posted: 07/08/08 06:40am Link  |  Quote  |  Print  |  Notify Moderator
My 29 RK Laredo has one battery. I never think of pluggigng it in or hooking to the truck to use the slide as long as the gbatt has some juice. The slide motor runs like the wind.
My old Wilderness was a different story. It was geared so high that sometimes I helped by pushing on the slide
If it is geared right and runs free, we are dealing with urban legend.
AlanB
Sierra Vista, AZ
Posted: 07/08/08 06:48am Link  |  Quote  |  Print  |  Notify Moderator
My slides will not operate with the main engine running either. We have two slides and I almost always operate them without being plugged in, never a problem. What does your operator manual say?
AlanB
2002 Holiday Rambler Imperial 40PKDD Cummins ISL
wilanddij
CA Desert
Posted: 07/08/08 08:20am Link  |  Quote  |  Print  |  Notify Moderator
Getting my slides to operate is fairly simple to understand, as you can see from the attached photo Slide Instructions.
Will & Di
2004 Southwind 32VS
Workhorse/8.1
Jeep Wrangler/Blue Ox
"We have met the enemy, and he is us" Pogo
BaldyD1
Central Florida area
Posted: 07/08/08 08:29am Link  |  Quote  |  Print  |  Notify Moderator
Our slides will not operate when engine is running; same as Joy's. We DO generally operate the slides when on shore power.
Speedy, Jackie & Dusty {Shih-Tzu/Maltese}
2006 Kountry Star KSDP 3912
2005 Saturn Vue (dinghy)
dougrainer
Carrolton
Posted: 07/08/08 09:55am Link  |  Quote  |  Print  |  Notify Moderator
Most OEM's want the RV plugged into shore power or have the APU (if you have one) On, so you have GOOD 12 volt power from the Converter or Inverter/Charger whichever you have on the RV. This will make sure you have good 12 volt supply if the batteries are low. Some RV's (motorhomes) have an Ignition lock out, so IF the chassis engine is ON, then the slides will not operate. This is NOT true of all motorhomes. Tiffin (Allegro) 2006 and newer require the Engine Key to be ON or the engine running to operate the slide rooms. There is no hard fast rule. But for the original poster, National used a Powergear system and you do NOT have to have the Engine On or Off. You can operate the slide room on battery power on the National with no problem, unless the coach batteries are low/bad. Doug
othertonka
Stockton, CA
Posted: 07/08/08 02:17pm Link  |  Quote  |  Print  |  Notify Moderator
That is exactly how my Power Gear slides work. (see the Link above for slide Instructions) I already replied to this post but forgot to add, You also have to have the parking brake applied on the Power Gear
Slide on my southwind before it will work, So that kind of prevents someone from trying to employ the slides while the engine is running and you are driving down the road. You don't drive down the road with the parking brake on. So to the original poster, do your homework and do what you think will work best for you, you have received so many variations of what will work, what will not work, engine running, engine off, ignition on, ignition off, But I will bet that all of them require that the parking brake be ON. Good luck
Othertonka
2004 Southwind 32VS
2002 CRV Toad
U. S. Gear Unified brake system
Retired Fire Captain, SFD
Clay L
Sioux Falls, South Dakota
Posted: 07/09/08 04:38pm Link  |  Quote  |  Print  |  Notify Moderator
I have electric slides and my manual says to have the engine running when you are operating the slides so that's what I do. It has worked fine for 4 1/2 years, so I guess I will keep on doing it.
Clay (WA5NMR), Lee,(Wife) Codi, Brandi (Shelties) and Damncat (damn cat)
Full Timing in a 2004 Winnebago Sightseer 35N, Workhorse chassis, Honda Accord toad
smkettner
Posted: 07/09/08 05:06pm Link  |  Quote  |  Print  |  Notify Moderator
DaveMac wrote:
Slideout motors will typically draw 50-100 amps DC so you are giving your batteries a real load test if not running the engine!
OK I do not have a big honking DP MH but my trailer electric gear driven slide draws 10 amps, 18 amps at stall. 50-100 seems like a lot even for an electric/hydraulic.
