RV.Net Open Roads Forum: Travel Trailers: Ea-Z-Lift problem
LovinTheSouthernLife
Mississippi
Posted: 07/08/08 11:43am Link  |  Quote  |  Print  |  Notify Moderator
We recently purchased a Jayco 213 TT, and have a dealer-installed EaZLift WD hitch and sway control setup. The problem is, while we were coming home last Sunday we apparently lost on of the clips that secure the chains attached to our spring bars! It's a gold-colored, small "C" shaped clip/pin, about 1/4" in diameter that is used to secure the stirrup-like bracket in the up position (thus applying tension to the spring bars). My question is, since this litle thing seems VERY important, yet apparently is inadequate, is there something better to use in place of these little clips/pins? I've looked online and found locking clips for couplers, etc. that would seem to work, but we're newbies so we're unsure what would be appropriate. Has anyone else had this problem? Any info would be GREATLY appreciated!
old guy
Oregon (pronounced Or e gun)
Posted: 07/08/08 12:13pm Link  |  Quote  |  Print  |  Notify Moderator
this keeps the spring bar in place, go to the store and buy another one, in fact buy two , one for a spare.
ghaindle
Louisiana
Posted: 07/08/08 12:20pm Link  |  Quote  |  Print  |  Notify Moderator
Small stainless steel machine screw and nut will do in a pinch. The pins should be used.
Fun Finder 18FBS
Expolrer Sport Trac w/3.73
Reese WD/Class III
NCHornet1
Mt. Airy, NC.
Posted: 07/08/08 01:23pm Link  |  Quote  |  Print  |  Notify Moderator
There are many different clips that can be used. Just go to Lowes and look in the hardware section. You can one that looks like a hitch pin clip, I think it is called a clevis pin. They are a bit more secure and not able to slide out.
NCH
2000 Ford F350 4X4 PSD,CC, DRW
4:10's, BTM Muffler, Isspro Gauges,
Coolant Filter,CCV Mod
FTVB , Ford AIS
6.0 Cooler,SCT2 W/DP's 40 tow & 80 econo,Zoodad mod
2005 Keystone Hornet 30BHSS
Reese Dual Cam
Family of 4 saved by Grace!!!
MY TRUCK
OUR TRAILER
Mississippi
Posted: 07/08/08 03:46pm Link  |  Quote  |  Print  |  Notify Moderator
thanks! i'll try lowe's...
wiretheboat
merritt island fl.
Posted: 07/08/08 05:30pm Link  |  Quote  |  Print  |  Notify Moderator
I have the same one and when I put the chains on I pull down on the pin so it is tight.
JeeperAz
Az
Posted: 07/08/08 06:54pm Link  |  Quote  |  Print  |  Notify Moderator
I have the same brand wd hitch and looked for another type of pin that was more secure but never did find anything. The hole in the bracket is too small of a diameter for anything I could find. I thought about drilling it out a little bigger to accept a different style but haven't gotten around to it.
'06 GMC 2500HD Duramax(LBZ)
'06 Ragen FB2500
Larry & Mindy
Backseat: Maya (black lab)
Mississippi
Posted: 07/16/08 08:55pm Link  |  Quote  |  Print  |  Notify Moderator
Well, I looked and looked, and finally found something which to me seems like a wonderful replacement. Since the holes in the brackets are quite small as JeeperAz pointed out, I was pretty limited. I found a 2 1/2" wire lock pin (1/4" post) at www.Fastenal.com. I bought 3, just in case. They fit very tightly in the holes, and the wire lock ensures that they don't come out till I want 'em to! They were cheap too, I think I paid less that $7.00 for 3 of them.
