RV.Net Open Roads Forum: Tow Vehicles: Removing the Lift from my 2002 F-250
Search only in Tow Vehicles
 > Removing the Lift from my 2002 F-250
94fxds
Rancho Cucamonga ,Ca
Posted: 07/08/08 11:55am Link  |  Quote  |  Print  |  Notify Moderator
I have 2002 Ford F-250 that I put a fab tech 5 1/2" front lift done with new leaf springs and a 3" rear lift done with blocks. I had this done when the truck was new and didn't keep the stock parts. I would like to go back to stock so i'm looking for someone in Southern California that has the stock front leafs and front end parts to go back to stock. 1999 to 2004 Ford F-250 would fit.
johntank
Oxford, Ms 38655 USA
Posted: 07/08/08 02:08pm Link  |  Quote  |  Print  |  Notify Moderator
Just an idea, check with a auto salvage yard to find the parts you need. Hope you have good luck finding your parts.
rsh_757
Auburn, WA
Posted: 07/08/08 02:13pm Link  |  Quote  |  Print  |  Notify Moderator
You can try the boneyard but I bet you can find aftermarket kits that have no lift with much better parts in them than stock for a reasonable price. Still sold by off-road stores and such but with better bushings and so on. Should be pretty easy to get theose front leafs. I had an '01 F-350 and got them from Gittspring on a screamer deal.
gittspring
2008 Cougar 310SRX 5th Wheel
2005 Dodge Ram 2500 QC 4x4 CTD
2008 Nissan Armada LE
JFordBronco
Ball, LA
Posted: 07/08/08 02:14pm Link  |  Quote  |  Print  |  Notify Moderator
Check with you local 4x4 shops and see if they have anything like what you need left over from someone elses. If they do, see if you can swap, they take off the new parts and install the used parts and dial it all back in. ?????? Thats what I would do
2007 Nissan Titan Off-Road w/ leveling kit
2008 Jayco Jayflight 28BHS
Me, wife, one little girl and one little boy
all along for the ride.
my3wags
Corona, CA
Posted: 07/08/08 03:10pm Link  |  Quote  |  Print  |  Notify Moderator
looks like there is a whole setup on Ebay off a 03. Check it out!
Big E and family of three
2002 F250 SUPERDUTY CREW CAB 4X4 7.3 PSD
Most of the goodies !!
2004 KEYSTONE SPRINTER 297 FWBHS
Some of the goodies
Hunting in the Imperial Valley !!!
Outoftowners
valley center,ca
Posted: 07/09/08 08:13am Link  |  Quote  |  Print  |  Notify Moderator
I have a set of front leafs off a 2000 f-350. These are Ford "Y" code springs that is probably what you had stock,you can verify with the door sticker. I upgraded to "X" springs for higher rating.
I'm just down the road from you in Valley Center, and willing to sell cheap.
Mark
